its on the rear "axle" if thats what you would call it, a rubber hose connected to a white plastic nipple going into the axle. Theres another white nipple next to it and theres no hose on taht 1, this is on the passenger side of the car.
When i put my new fual tank on today i noticed it was snapped off at the white nipple.
What is it an shud i be worried/pissed off its broken.
Cheers Pete
whats this pipe?
- Pedro_mx3
whats this pipe?
I'm not worried about the bullet with my name on, Im worried about the one that says 'To Whom it may Concern'....
Make a Donation, Keep Mx3.com Alive!!
1991 V6 K8 -- My baby, i miss her... On her way to car heaven... <3
Re: whats this pipe?
Wat? Can you take a pic?
- umcamara
I know which piece you're talking about. It's a white nipple sticking out of the rear cross-member on the driver's side, facing towards the front of the car. I have no idea what it is either, but it has a rubber hose that connects to some sort of solenoid in the back end of the car. It makes no sense to me either. It doesn't seem to show it in the online manual.
- Pedro_mx3
aye thats the 1, so should i be worried about it neing broke off ? obviously im gonna try an reattach it but it wasnt so happy about the rejoining with glue so gonna have some fun mateing it up
- umcamara
Well you can pull the rest of it out of the cross-member if you're careful. It's clipped in there like any of the other clips on the car.
I think a good way would be to warm it up a little with a heat gun, just so the plastic isn't too brittle, then gently pry it out with a flat-blade screwdriver. You can get a replacement from a wrecked MX-3, and that's where you'd wanna be really careful removing it.
I'm still curious to know what the heck that little system is for...
- umcamara
I think that little system may have something to do with the fuel and emission control. I'm not sure, but I think that little solenoid type thing that I was talking about that has the hose that runs to that little white nipple among other parts, may be the check valve or the check and cut valve. These parts are responsible for controlling the pressure inside the fuel tank, and making sure that fuel doesn't flow into the charcoal canister.
Again, I'm not sure that this is what this system is, it's just an educated guess.
that should be for the evap system, if i am thinking correctly.
- Pedro_mx3
ok so gluing the nipple back together is out of the question then? if it requires a small amount of pressurisation?
WTB the white nipple and pipe shipped to UK :>
