i need help
i need help
i have a 1992 mx3 the problem is that it doesn't want to turn on it tries to turn on but it doesn't i bought new spark plugs new Spark Plug Ignition Wires i bought the fuel pump i also bought that thing that is kind of round that throws electricity to the ignition and nothing and the car is throwing good electricity and my tank is almost fuel if ya can help and tell what can probably be i wil thank ya alot god bless
Re: i need help
I am not trying to be rude, but based on the description you've given you would have been better off spending your money on a mechanic. That is my suggestion.
Re: i need help
The thing that is kind of round? Distributor? Coil? Alternator? It sounds like you are just throwing money at it without trying to figure out the symptoms. Just because you have a new fuel pump doesnt mean you are getting fuel. Have you actually taken off a fuel line and seen fuel coming out? How are you checking for electricity? Everything turns on in your car or you checked for spark at the spark plug wires? When you changed the plug wires, did you put them back on in the right order? I have given you a few things you could check on your own, but I'm with wytbishop, you would be better off taking it to a mechanic. Oh, use some grammar man, that whole sentence if you can call it one hurt my head.
93 323 Bp'd, Front and rear strut braces, Mx-3 seats, JDM headlights and grill SOLD
93 Mx-3 GS Curved-Neck KLZE, 5 speed Conversion, Fidanza Flywheel, Cross Drilled Rotors
Re: i need help
what up red line y checked te fuel line and it is coming out normal by the way a mechanic is working on ma car not me peace
Re: i need help
I'd post up that Samuel L Jackson pic but I'm obviously too lazy. ![Laughing :lol:](./images/smilies/icon_lol.gif)
Re: i need help
AIN'T YOU EVA SEEN MAH MOVIES!?!?!?
A F@CKIN SHARK ATE ME!!!!!!!
![Image](http://i659.photobucket.com/albums/uu316/93vtecklr/ClintsSig2.jpg)
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
