I just filled up and there was pressure in system I think as I've hear hissing every time I fill up.mazda___mx3 wrote:check the gas cap as well, if its leaking the gas tank wont have any pressure, You should here a some air escaping when you remove your gas cap
Can I check fuel pump with voltmeter to see if it's broken?
