Changing over to ZE disty..Help
hey everyone k my ze disty cap came in so 2morrow i will be changing over to the ze disty i just have one issue the k8 harness is 6 pin and the ze disty is 4 pin. now 2 pins from the k8 harness r beening used for the hei which leaves me with 4 pins then i thought sweet but then i looked closely but one wire on the k8 harness has been blocked off neone notice that if so what do i do ? thanks
Re: Changing over to ZE disty..Help
the diagram posted in your other thread shows exactly how it works - the 6 pin plug goes on the top of the disty... the 3 pins that went into the side of the disty and 1 pin from the 6 pin are used for the HEI part... just study the diagram - it took me a bit to make sense of it when I did it too...
http://www.mx-3.com/phpBB3/viewtopic.php?f=15&t=69868" onclick="window.open(this.href);return false;
if you can get another one, the plug from the fuel rail is the same as the 4 pin disty one...
![Image](http://i806.photobucket.com/albums/yy344/Mooneggz/laguna_seca_signature.jpg)
i got a plug for the disty from a 2.5 millenia fits perfect the only thing that confuses me is that i got 3 wires from the harness and 4 plugs in the ze disty u know wut i mean
OK...
there are 2 plugs on your stock distributor and 2 corresponding plugs on your K8 harness. The 3 wire which were connected to the 3 pin plug will connect to the external coil (the tach signal wire and coil neg to neg and coil pos to pos). From the 6 wire plug in the harness, the orange wire goes to the HEI module, the igniter signal wire is cut and the other four go to the 4 pin plug on the ZE disty. However...the order of the 4 wires is reversed on the ZE from how they were on your K8 disty. If you look at the plug in the orientation it was in when plugged into the K8 disty, and the remaining wires are 1 - 4, with #1 being closest to the rad, on the ZE disty #1 will be closest to the firewall. Get me?
Just wire you new 4 pin to the 4 remaining wires on the harness and try it. If it doesn't work you probably have the four wires reversed.
and one more thing sorry i need the proper rotor for the ze disty cap when i go to the store wut do i ask for cuz i know the k8 rotor doesnt work
you do realize that you need the entire disty right? did you just get a cap?ramsen25 wrote:and one more thing sorry i need the proper rotor for the ze disty cap when i go to the store wut do i ask for cuz i know the k8 rotor doesnt work
the cap and rotor cannot be ordered from a parts store... dana and I spent an hour or so browsing through his catalogs... we ordered a bunch of different ones just to see if any would work and none would...
![Confused :?](./images/smilies/icon_confused.gif)
i already has the disty and the cap to i just need a rotor
![Image](http://img502.imageshack.us/img502/5229/heicoilzeff8.jpg)
Try a 93-97 MX-6 rotor. That's your best chance.
if ANYONE can find one that works please post up where you got it AND the part number... I searched diligently and failed... good luckwytbishop wrote:Try a 93-97 MX-6 rotor. That's your best chance.
i have the actual ze rotor but its broken in half im gonna attempt to put it back together but i will be tryin to buy the rotor 2morrow and ill let all ya know 2morrow
- WhiteFinish
Sorry for getting this one up again
But here is the problem with the plug I got
![Image](http://i656.photobucket.com/albums/uu289/reaper_033/Foto0107.jpg)
It doesn't match with the colorcoding from nd4spd
ill take pics of mine and post them for u
It doesn't matter what color wires are coming out of the 4 plug, what matters is you put the correct wires into the 4 plug!
my suggestion would be to carefully remove the 4 existing wires from the plug... this can be done with very tiny flathead screwdrivers (be very careful) coming in from the inside - there is a tiny little piece that holds it in place you push that lets you pull the wire out the back Using the same process, remove the 6 wires from the normal plug and then plug the 4 correct wires into the new plug...
this way you don't have to cut and rewire at all!
(it's what I did
![Idea :idea:](./images/smilies/icon_idea.gif)
I now what he means the yellow cable on 1 or on 4
orange cable on 2 or on 3
red/black cable on 3 or on 2
black/red cable on 4 or on 1
becouse a few post above they say mount it backwords??
how must he connect the plug
in wich order?
greetings kevin
in wich order?
greetings kevin
