quick question about K8 head bolts
K8 engine is still at my house. I want to sell it to a junkyard. Need to take it apart first.
Can I just a regular 13mm socket to take off the head bolts or is there is a special socket to take them off?
Thanks
Thanks
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
Re: quick question about K8 head bolts
Is that going to be a dealership part?
I went to AutoZone, they dont have a 12mm 12pt socket
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
try some other places with tools maybe even home depot.
- marcdh
That's weird most socket sets here are 12 point.
View Worklog
View Worklog
Heh, i found like 3 of them in my dad's box of random sockets
Ok I found one
Another question, do the 2 allen bolt on each head have to also be removed or is it just the 8 12mm 12pt bolts on each head?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
Pretty sure it's just the 12 mm ones.
Yep, you just take out the eight head bolts (in each cyl head) and the head should pull right off. Also, the right cylinder head has the egr valve on it so you'll have to take that off or else it won't pull off. It suprised me that the head bolts were only 12mm and 12point at that when I re-did my head gaskets.
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD
Buyer Feedback: viewtopic.php?f=37&t=62426" onclick="window.open(this.href);return false;
viewtopic.php?f=37&t=69003" onclick="window.open(this.href);return false;
"Amatuers practice until they can get it right; professionals practice until they can't get it wrong"
