Where to attach on engine to Pull
- ooELMOoo
http://www.mx-3.com/manuals/showimg.php ... B2-050.gif" onclick="window.open(this.href);return false;
Manual is not really clear on where to hook into the engine. Is it the 2 silver hooks?
Thanks
Thanks
| CUSTOM X3|
| CUSTOM X3|
- Evo_Spec
Re: Where to attach on engine to Pull
really when your taking out an engine, it doesn't matter where you bolt it to, just bolt it to a large bolt that will keep the engine stable
- ooELMOoo
I just don't want to bolt to the wrong thing and say bye bye to the klze!!
| CUSTOM X3|
| CUSTOM X3|
Ya two hooks, one by the coolant cap the other in front of #6 cyl. The engine is fairly well balanced when you use those. If you connect anywhere else the engine could adopt a not so good angle.
- ooELMOoo
I can't wait :>... THanks
| CUSTOM X3|
| CUSTOM X3|
- ooELMOoo
thats a quality answer .... Thanks
| CUSTOM X3|
| CUSTOM X3|
You're about to pull an engine, and you don't even know the basic things, like where the hooks go? Ok, good luck.
- ooELMOoo
I was unsure as the manual wasn't clear. . . . I have never pulled an engine before, but have done a bit of other engine work.. Got to start somewhere
| CUSTOM X3|
| CUSTOM X3|
Yeah, I guess you do have to start somewhere.
Be sure to mark and label EVERYTHING that you disconnect, including all the bolts. If you got a camera, take pics, too. Will save you a lot of trouble when you're putting things back together.
