JW,
I was quoted $4k USD for a dog gearset, given current exchange rates thats $8k NZD
( I can build a compete KLZE 323 for that cost! and have it run 12's all day!)
I used to have access to all that machinery, Id wire cut the final gear shape as you can
heatreat first then wirecut. I did a set of timing gears once for a small block very smooth.
RPM Engineering Have been making three peice four rotor shafts for a long time, google
http://www.youtube.com/watch?v=Au7F2ttEXWU
Thats my "home" track, "fourre" now has a airshifted four speedbox
With a ATX, kiss goodbye lag, be able to set differnt boost settings for each gear
gain well over a second if not two due to the autobox being able to shift faster
than a human on a MTX. ( proven fact guys )
Though when I go turbo It will be a RWD car and a autobox more than likely a manualised
C4 as they are cost effective and bullet proof!
Im going to build another N/A KLZE 323, though this time it will be more focused on being
a pure FWD drag car than a street car and try and get the weight down to 800kgs minus driver
though still be low volume certified for street use.
I still Impressed ( or rather put the fear of ???? ) with the old 323 considering the old tart was
900 kgs on the scales ( not including my lard a-- of 75kgs ) and no aerodyamic mods at all!
Its one thing to sit infront of a computer model programme and move figures about to doing it
in real space and time is another. still its interesting!
However, the current fastest FWD pro import in NZ currently stands at 9.88 @ 236 kmph
Its one record that I would love to have a go at! hence the ATX
( though there are weight rules around power units and power adders, body shapes and other
silly stuff! )
I think the last gearbox failed not due to Hp or torque ( as my motor makes a misserable 200 FTlbs on the dyno )
but more the synco breaking and going west ( or east ) through the box and jamming the gears.
