some questions
some questions
ok so i wont to redo my suspension because its gone so i have been searching around and found that the zx2 struts seems to be a popular choice with the suspension tec springs. what i wont to know is,
were the best place to buy the springs (i live in calgary)
i wont to buy new mount because my have cracks in them or atleast the front ones but what ones do i buy (were my strut bar sits)
I am also ording ZX2 Front Upper Strut Bearing,ZX2 front/rear dust boots,and MX-3 Camber bolts
anything im missing???
92 mx-3 gs,klde,spec stage II+ clutch,awr 88mounts, remaned axles,CAI,seven nipple ditsy, new alpine speakers,panasonic 7'' dvd deck ,10'' kicker l5, hei mod, removed air box. 17 sortmaxs 10 spoke white nexan n700 tires
now wrote off with a watermelon sized dent in the driver side quater panel
93 mx-3 gs black klze fully loaded
Re: some questions
im using the same set up... i just bought the springs from part source dont know if they have it there... the struts i bought from ford..but i have seen links on here for much cheaper then what i payed..and the mounts i would get from mazda or a junkyard..and dremel them out to the right size..
- Evo_Spec
Re: some questions
by mounts do you mean the rubber mounts? well actually, if there's any parts you need stop by the calgary pink n pull there's a couple mx-3's there
Re: some questions
yea i wont to buy new rubber mount but wont the zx2 work or not just it would make it easyer they looked close but i have inly seen pics
- RS_OBD'oh_2
Re: some questions
I picked up my HP's (for the mx-3) and eibach's at contemporary motorsports (was in the same building as tnt honda).. I think they moved, but worth while to give them a call. The upper strut mounts I got from mazda as well as the dust boots and bump stops. IIRC the hole in the upper strut mount needs to be drilled/bored out to fit the zx2 struts.. I could be wrong.
This will be the best upgrade most people will ever do. Enjoy it!
Re: some questions
OK i know that you can use the mx3 ones what im asking is WILL THE ZX2 WORK IF I ORDER THEM FROM FORD I HEARD THEY WORKED?
Re: some questions
The MX-3 and Escort ZX2 upper strut mounts are the same. Exactly. Front and rear. If yo ucan find a low miles 95 - 00' Escort at pick n' pull...you're golden.
Re: some questions
Define: wont:
# One’s habitual way of doing things; To make (someone) used to; to accustom; To be accustomed; Accustomed
Define: want:
# desire: feel or have a desire for; want strongly; "I want to go home now"; "I want my own room"
# have need of; "This piano wants the attention of a competent tuner"
# privation: a state of extreme poverty
# hunt or look for; want for a particular reason; "Your former neighbor is wanted by the FBI"; "Uncle Sam wants you"
# lack: the state of needing something that is absent or unavailable; "there is a serious lack of insight into the problem"; "water is the critical deficiency in desert regions"; "for want of a nail the shoe was lost"
# wish or demand the presence of; "I want you here at noon!"
# need: anything that is necessary but lacking; "he had sufficient means to meet his simple needs"; "I tried to supply his wants"
# be without, lack; be deficient in; "want courtesy"; "want the strength to go on living"; "flood victims wanting food and shelter"
# wish: a specific feeling of desire; "he got his wish"; "he was above all wishing and desire"
Sorry, just a little grammatical OCD moment.
Define: want:
Re: some questions
I am also wont to correct those who make simple mistakes...
That for instance, was a correction of his diction, not his grammar.
Re: some questions
wytbishop wrote:I am also wont to correct those who make simple mistakes...
I... I uh... I... damnit.
