What is the Best Brand Clutch?
I am going to be using the stock Flywheel and wanted to know what is the best Clutch I can buy that will give me long life? I have a Mazda GS 1993 1.8L.
Re: What is the Best Brand Clutch?
There's plenty of topics on clutches...search the site for clutches for KLZE's and the same manufacturer. They're literally the same clutch no matter if it's for a 1.8 or 2.5 V6's. Get those recommended manufacturers and stay away from eBay no-name and "JDM" clutches.
- johnmx3ze
i bought a clutch on ebay F1 racing clutch stage 3 for my ZE with my 1.8 tranny and the clutch was a piece for s---...it was done after 3 mounts... so now i bought an expensive one compaired to the F!.. my clutch right now is a bully performance clutch stage 3...its perfect and im turbo... its never slipped once... so DONT buy ebay s---... do it right the first time and you'll save money in the end...
I sent you a PM but clutch masters come highly recommended.
I bought a f1 racing clutch stage 2. don't seem to have a problem yet... bought it off ebay in auguest.
- WhiteFinish
Clutchmasters
Xgreddy
Centerforce
ACT
A lot of them
Don't go XTD... bad expierence. After 20k miles it was gone on my ze (normal driving)
Xgreddy
Centerforce
ACT
A lot of them
colinf004 wrote:I bought a f1 racing clutch stage 2. don't seem to have a problem yet... bought it off ebay in auguest.
Yet crossing my fingues
lol
Unless you do the labor yourself, the clutch isn't something you want to cheap out on and have to pay for a new clutch AND labor again...
You get what you pay for and it cost more in the long run.
- onlytrueromeo
He's got a STOCK 1.8L...and you're all giving him performance clutches that he doesn't need.
Get an exedy organic clutch, the stock one is fine...it will be cheaper and hold up perfect to your 1.8,,,just remember to break it in!
If you plan on upgrading to a bigger engine or going turbo, look into performance clutch. I have a clutchmasters stage 1 on my ZE and its been great since august...excellent pedal feel too. Pucked clutches will chatter so I would stay away from them since you don't need one, and also stay away from kevlar if you can!
Now when you mean Break in use it normaly for about 500 miles right?
- onlytrueromeo
use it normally for ~3000 miles will probably give you the best break in, but ~500 for a stock clutch should be OK. Drive normally, dont rev past 3k, dont punch it into lower gears, don't launch from a stoplight, etc.
- tehbrookzorz
Another to think about with performance clutches is South Bend.
Cody
- mx3autozam
If its just a stock K8 like you said. Just go buy a normal oem clutch for a mx6 2.5L klde. its bigger disk and will last awhile ona k8 if you take care of it.
Anyways I got ACT hdss and love it. It ha s anice positive feeling an has never let me down. the pedal is a bit harder than stock but once you get used to it it is simple. Clutchmaster are really good. But from expereince driving them I just don't like how they feel. South Bend is really good and have been proven as well as Bulley. Canadian comany if you wanna support them too
93 Mazda MX3 KLZE Turbo
- fowljesse
I have an Exedy organic on mine, and my engine is built to be very torquey, and is about 200HP. It grabs and holds really well. The only time it ever slipped was when I drag raced for the first time, and shifted badly in the higher gears. On the third run it started to slip a little, because my shifter was sloppy, and caused me to shift slowly while the RPM climbed.onlytrueromeo wrote:He's got a STOCK 1.8L...and you're all giving him performance clutches that he doesn't need.
