K8 ECU on KLZE engine cause car to sputter?
Re: K8 ECU on KLZE engine cause car to sputter?
Black smoke is a symptom of being too rich or something bad in the ignition system. But my VAF was also bad so that might have caused a part of it, although it didn't smoke with a KL31 chip and the bad VAF.
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated -- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
When I ran my ZE with a K8 ECU/JE50 for a few days, it was stupid rich.Mad Cow wrote:Black smoke is a symptom of being too rich or something bad in the ignition system. But my VAF was also bad so that might have caused a part of it, although it didn't smoke with a KL31 chip and the bad VAF.
Yes and no. In terms of peak power, maybe, but in terms of putting the power to the ground, if you have a wider band of a higher output, you'll be quicker on the street or strip. I think Deimos's dyno shows that very well when he dyno'd with a Probinator the second time. The VRIS points were obvious and looks like his average power output was significantly higher. He did add more mods like a CAI, exhaust and a Fidenza, but if you even the max output, you'll see it's smoother with less dips in powerMnemonic wrote:And if i said it once I'll say it again, different VRIS settings plays a very very very, very very very, very very very limited roll in your over all performance, i've tried every single vris setting from every single K series engine that i could possibly find, and the dyno numbers were off no more than 5whp in either direction (which with that small of a margin the numbers are really the same). All pulls were done under the same condition, with NO VRIS being the control. The only visible difference is a slight shift in power. In any of the settings the difference wasn't great enough to make any real difference in performance.
OK the problem remerges.
Today I was driving and I was getting above 3k RPMs and the car starts sputtering again. It sputters until it dies.
New spark plugs, plug wires, rotor, cap, timing
I hope I can figure something out tomorrow
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
have you checked the the JE50? maybe it is bad? what about the fuel filter - is it clogged?
That's weird you guys were able to drive around normally with K8 ecu/vaf... my car was basically undriveable. There was a black sooty puddle under the tailpipe every time i ran it in the garage (condensation and carbon).
Swapping in the new ecu/vaf made a night and day difference. If anything I'm a little lean now.
Juan, what do your plugs look like? Hook up a timing light and see if you are still getting spark when it stutters.
Smells like disty to me.
Nd4SpdSe wrote:When I ran my ZE with a K8 ECU/JE50 for a few days, it was stupid rich.Mad Cow wrote:Black smoke is a symptom of being too rich or something bad in the ignition system. But my VAF was also bad so that might have caused a part of it, although it didn't smoke with a KL31 chip and the bad VAF.
That increase isn't significant enough to warrant the statement 100% true, it is a probinator chip which I believe has an adjust fuel map to "make more power". Vris is simply a nice way to shift where the power is on the curve. And if that is a probinator chip he needs to send it back lol, I made more power with a kl31, cai, pacesetter catback and fidanza and my home made vris controllers. Basically the same bolt ons as him. lol probinator adds more power HAH! Lies... Me thinks all these guys with probinators believe the butt dyno to much
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
well when the track opens up next spring I could take both ecu's to the track and see how it goes
if we ever do a dyno day I could do the same thing as well and maybe finally have some concrete evidence.
