mx6 tranny in a mx3
mx6 tranny in a mx3
i have read alot butcant seem to find one thing. i know the gears will match up, and the cases bolt on, but i am ordering a set of cvs from cvtech, and i need to make sure the splines are the same and if the length is the same as stock
klze swap, wisco 8.5 comp pistons, pauter rods, act stage 3 clutch, lightened flywheel, UR racing pulley, flex-o-lite oil cooler, 2.5" custom exhaust with high flow cat, B&M short throw shifter, S&R cross drilled rotors, , B&G lowering springs, maxxim 17" gun metal rims, modded nissan injectors, walbro 255 lph fuel pump, areomotive afpr, msd 6a , magasquirt v3, and turboed
Re: mx6 tranny in a mx3
I have a 626 tranny and mx-3 axles fit just fine (length and splines and I believe it's the same overall as the mx-6 tranny)...
![Image](http://i806.photobucket.com/albums/yy344/Mooneggz/laguna_seca_signature.jpg)
thanks man
