What is there to know? Are you hooking up a wideband? If you were to buy say... "AN" AEM uego. It comes with the guage and the oxy sensor. You screw the sensor into the o2 bung in the exhaust. You power and ground the guage. You plug the connector side of the sensor into the back of the guage. Some calibration may be req'd.
AN
AN
AN
you must use "AN" instead of "A," pending on the leading letter of the following word.
