KLZE is in, evrything ready to go but wont start
Juans_93_MX3
Post by Juans_93_MX3 »
I got 2 problems after the 5pd/KLZE swap
Key doesnt want to come out of the ignition. I try to turn it all the way down to the position where its suppose to come out of the key. Thing is, it wont want to turn all the way down. It only wants to stay at START.
And two, I think its going to be the spark. Waiting for someone to test it out.
I turn the ignition, the crank turns over but thats it. All I hear is the crank turn over. It doesnt want to fire up. The only sound it makes is the crank turning over. I dont believe its going to be the starter. Im pretty sure its connected right.
I dont believe its the fuel because I sniffed around the fuel rail 17mm bolt, and it smells like fuel (not strong).
If its not the spark... which I believe it will be but..., can it be the timing?
Im thinking its going to be the disty.
2008 Mazda 3
1993 MX3 GS
solo_ryder
Re: KLZE is in, evrything ready to go but wont start
Post by solo_ryder »
Check my thread, looks like we are having the same issues:
http://www.mx-3.com/phpBB3/viewtopic.php?f=15&t=67086
Dali
Post by Dali »
your ignition problem is due to it having the safety slider from when it was a auto, there is a peice of plastic that shifts only allowing it to start in park or neutral. you have to take the cover off and play with it, i removed the plastic peice and it works just fine. no start could be from the fuel lines back wards, if you re and re a motor and plug everything back in that is one of the few problems besides a missing ground wire.
1993 White gs klze.
WaaX
Post by WaaX »
Pull a spark plug out, wire connected, and ground off the plug to a part of your car (like the frame or something), check to see if youre getting spark.
If you are, and its still not starting, then your rotor is in the wrong position, play with it and hopefully she will start.
Good luck.
14.985@92.54 MPH
Red 93 MX-3 GS, KLZE, 5 speed, Act clutch, short throw shifter, HEI w/blaster 3 coil, PIAA ultra white headights, CAI, Apexi Dunk muffler w/2.5 inch cat back, Avital alarm, dark tint, Sony Xplode 52x4 head unit, Clarion speakers in the front, Pyramid 6x9's in the back, Volfenhag 2000 watt amp, 3x crappy MTX 10 inchers.
