This setup consists of modified 95 EGT spindles that have been powdercoated, wilwood 4 piston brake calipers, willwood 2 piece 11" rotors, Russell stainless brake lines, new oem hubs, ARP chromemoly wheelstuds, new oem hub bearings, new ball joints, new tie rod ends, and a pair of custom machined 8mm aluminum spacers. With the spacers installed these brakes will clear both 95 EGT and 99/2000 ZX2 S/R wheels (both 15 inch). I havn't tried any other OEM wheels on them.
I weighed these spindles at 29.4 pounds as pictured with ball joints, tie rod ends and brake lines. I weighed worn out stock components and got a weight of 36lbs even. Thats 6+lbs weight saving per corner for you autox'ers and the like.
The price is $1200 outright or I'll deduct a couple hundred for a showroom condition set of SE front seats. The seats must be in absolute perfect condition or I am not interested.
Here are some pics that where taken before installation. I'll take some current pics tomorrow or some time this weekend showing all components, brake lines, and the spacers.:
(Scroll down for current pics)
