What's your speed @ 4K rpm?
- fowljesse
So Mooneggs asked what MPH I was at @ 4,000 RPM because he wondered what the difference was between my K8 tranny, and his 626 is. Mine is at 79, and his is at 82. Maybe our speedos are off, or something. We both have stock 15" wheels. So, what's your speed at 4K, and what gears do you have?
Re: What's your speed @ 4K rpm?
At 4k im in the 80s. I have a PGT trans
at 4000 i'm at 120kph...73mph on stock K8 tranny.
edit: On the way into work this morning I checked and it's closer to 78-79mph than previously stated.
before i messed up my guages, i was doin 130-135 at 4000rpm...not sure if my 17's were throwin it off, but i normaly cruise the highway at 3000rpm steady at 120
thats with k8 auto trans
![Image](http://i295.photobucket.com/albums/mm158/tmac4t4/IMG_0163-1.jpg)
![Image](http://i295.photobucket.com/albums/mm158/tmac4t4/IMG_0181-1.jpg)
![Image](http://i295.photobucket.com/albums/mm158/tmac4t4/0908281820000-1.jpg)
![Image](http://i295.photobucket.com/albums/mm158/tmac4t4/0909061631000-2.jpg)
Pgt trans and MX3 trans are the exact same.coltfoet5 wrote:At 4k im in the 80s. I have a PGT trans
maybe your pgt got an mx6 trans.
-hec
this is just like my k8 is as well...wytbishop wrote:at 4000 i'm at 120kph...73mph on stock K8 tranny.
![Image](http://i806.photobucket.com/albums/yy344/Mooneggz/laguna_seca_signature.jpg)
Ah, you may be right I forgot I put a new tranny in my probe last summer with the ze. It might be out of something newer.
mine tooMooneggs wrote:this is just like my k8 is as well...wytbishop wrote:at 4000 i'm at 120kph...73mph on stock K8 tranny.
K8 :: 136.8 bhp---160 nm---108.0 whp---118lbs/torque
ET: 15.567 @ 136 kmh (84 mph)
![Image](http://img148.imageshack.us/img148/79/rx78tqdv4.png)
"Racing a Honda is like being in the special Olympics, you may win, but in the end your still retarded."
No matter if you have a K8, KF or KL, your RPM's will not change because of the motor. It'll change cause you've either got a different ratio tranny, or you've changed the size of your tires
Mx-3 & Probe : 4.38:1
626 & Mx-6: 4.11:1
Myself, with my K8 tranny, regardless of K8 or ZE motor, i do about 120km/h @ 4000rpms
626 & Mx-6: 4.11:1
Nope
Nd4SpdSe wrote:No matter if you have a K8, KF or KL, your RPM's will not change because of the motor. It'll change cause you've either got a different ratio tranny, or you've changed the size of your tires
626 & Mx-6: 4.11:1
VERY well said!
-hec
- fowljesse
Anyone else with 4.11:1 gears?
i do 120 at 4000k ze engine k8 tranny. so the big difference is about 10-15km/h.
i am currently looking for a 626/mx-6 tranny.
- Yoda
With a stock tranny I was doing about 120kph@4000
with 4:11 approx 140kph@4000 (swapped 06/1997 with engine)
with 0.69 5gear swap almost 160kph@4000 (swapped in 1998)
BTW My cars been off the road and in storage since 2001 with a blown tranny.
