Which Oil Is Best For Mazda Mx3 1993 That Burns Oil
ElectricEnergy
Re: Which Oil Is Best For Mazda Mx3 1993 That Burns Oil
Post by ElectricEnergy »
Hahah, yes. I did timing belt, water pump, most the gaskets/seals, acc. belts, clutch/flywheel (you have to do this one, the stock clutch wont handle the motor). and some other basic stuff.
I think the project ended up costing around $2200-2400 in all.
Ashton Janzen
Post by Ashton Janzen »
I dont have a stock clutch i redid it when i bought the car.
ElectricEnergy
That'll take a pretty big chunk of the cost out then. Which one did you go with?
Ashton Janzen
dont remember. costed 900 bucks tho
solo_ryder
Post by solo_ryder »
Yea, just replace them along with the timing belt tensioner and new timing belt belt bearings.
I am guessing you are in the vancouver area?
Ashton Janzen
No i am in saskatoon.
Ashton Janzen
hey david could i get you to just do it for me and i will pay you in full. that would be so much easrie for me.
blaudust7
Post by blaudust7 »
Just keep your eye on the oil level and find out when you need to change. I burn a little bit of oil too with the K8 and change oil about every 1700 to 2000 miles. I use 5w30 with 219,000 miles and the car still runs great. I have used some stuff called AutoRX. It seemed to help a little.
