OutlaW-1997 Mazda MX-3 K8 V6
Re: OutlaW - 1997 Mazda MX-3 K8 V6 - Portugal
i just ordered these new parts:
K1 10mm sparkplug wires
6 Denso Iridium sparkplugs
MX3 gauge bezel CF look
K8 :: 136.8 bhp---160 nm---108.0 whp---118lbs/torque
ET: 15.567 @ 136 kmh (84 mph)
"Racing a Honda is like being in the special Olympics, you may win, but in the end your still retarded."
Just a milestone in my MX-3 V6 life
And it will reach at least 200 000kms
- Savin
Outlaw, I've been meaning to ask you...
What color and brand purple paint is that? Its all metallicy and shiney....I want it! lol.
Almost forgot: Congratz on the milestone!
'93 MX-3 GS - SOLD!
'93 MX-3 GS SE - Parts car!
'94 MX-3 GS - Scrapped
'94 MX-3 RS - Scrapped
'96 Sunfire SE - Scrapped
'03 Sunfire SE - Deathtrap
'95 Cavalier Base - Scrapped
'89 Mustang GT - SOLD!
'93 MX-3 GS - SOLD!
Savin helloSavin wrote:Outlaw, I've been meaning to ask you...
well, to the you the truth ... if i told you the paint's brand and colour ... i would have to kill you
So i guess it's best not to go that way ...
im jokin, i cant remember those things, and im at work right now, when i get home later today ill try and find out
i just found a good picture about my Intake Filter
Those parts look sweet!
Info on the intake??
93 MX-3 2.5 KLZE - KL101 \\ H&R Springs \\ Short Shifter \\ 17" ADR Rims \\ 205/40/R17 Namkang Tires \\ Millenia Manifold \\ Rockford Amp \\ Rockford 12" Sub \\
--- K8 was my gateway drug.
smooth, the only info is that u should ALLWAYS check for aftermarket parts available for our MX3.
The pipes are real cool to look at, but im going to spend a lot of money on silicone reducer's just to make it fit
It will be custom allright, but expensive
today i received a couple of silicon reducers, and a pipe for my intake ... let's see if i can make my custom intake ... maybe soon now
Here we go, my custom made MAZDASPEED c.a.i. is made and in place
The sound: i thought that it would make a lot more noise, but it's just the other way around.
I really cant hear my intake from inside the car right now
The power: I know that you guys are the MX3 guru's... but let me tell you, for a simple intake , my car pulls a lot better from down below.
My bet is --- +10 nm @ 3000 ... i dont know
Driving, it feels like 30 nm , but i know that it's the DIY virus
When i can, i will take some pics
- fowljesse
To be honest, That filter looks restrictive. That's probably why it's quiet. If you replace everything, including the ribbed duct, and put on a K&N filter, you will hear it. I'd like to see what you made.
jesse, what do you mean by restrictive ?
I used the same intake, and it made a clean bear growl sound ... i thought that since i placed it in the hole behind the fog light, it would be louder.
But that's not the case, at least from the inside.
I did not replaced the ribbed duct, it's found it's place in my custom intake.
A K&N filter is open, it sucks more air, but it can suck any water in the premises
I want to clean it up a bit, and then ill take the pics
- fowljesse
Since I can't see any of the actual filter, the air has to change direction alot, to get to the smooth flow in the ducting, and it looks like there isn't much room for a filter, compared to the open types. Also, the hole where the air goes in looks like it's about 1/3 of the surface area of the open cone type.
Some would say that the intake doesn't make a difference, but I think you'd gain a HP if you replace the ribbed part with a peice with a smooth transition, and put on a cone filter. I used a modified stainless steel Martini shaker. It has a smoother transition than a silicone reducer.
No matter how big the surface area of your filter, it will not change the amount of water in the air... but K&N makes a mesh filter that fits around a cone filter, that filters out water. I'm going to use one when I finish my ram air set-up
today a relative gave me a place to store my car during the night, and work on it at daytime
My DIY jobs are going to improve now
When i have the engine bay with a bettter look, i will take some pics
I think that the car is going to get some bhp soon
