nightfire - 1996 MX-3 GS
Re: nightfire - 1996 MX-3 GS
seriously... get us pics!!!!!
It sounds pretty sweet man, keep at it!
Um, I have the KLZE in my 96 for almost 3 weeks. i have no FP reg. im confused on why it would be necessary?
Im currently think of doing a car PC as well.. i have a 7inch tft. but its not touch... might just use as a secondary display for my laptop for GPS on long trips..
what linux GPS software are you using? im kinda noobish but run Ubuntu 24-7 so want to see if i cant use for gps as well... dont want to have to switch to having a XP partition for in the car.
1996 MX-3 GS - rollin' on Rota Slipstreams, (Red, Deep Tint, Black Lip)
True Straight Neck KLZE with TB relocate. Custom Cold air Intake. 2.25 Exhaust to Bosal muffler.
ACT Stage 2, Fidanza Lightweight Flywheel, Short Shifter with CorkSport Bushings and SS Clutch Line.
Suspension Techniques Springs On Zx2 Struts. SRD Control arm Bushings, Custom Sway Bar Links
Someone said something about the mix being too rich and lowering the fuel pressure to compensate.. dunno how much truth there is to it. Do you have an OBD-II -> USB adapter to read your fuel trims?JoshVK wrote:Um, I have the KLZE in my 96 for almost 3 weeks. i have no FP reg. im confused on why it would be necessary?
I'm actually just running iNavigator under VMware. It's not ideal, but it works. If you go this route I'd recommend the fastest machine you can find.. it runs kinda choppy on my Via C7 2ghz.Im currently think of doing a car PC as well.. i have a 7inch tft. but its not touch... might just use as a secondary display for my laptop for GPS on long trips..
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
Updated with KLZE swap info and pics on first comment.
- Gord
- fowljesse
Nice!!
I just read your post about the headers only having two o2 sensors positions after I had already PM'd you. Once I get my headers I'll get stainless nuts fabricated to properly fit the periferal of the pipe. Then have them welded after drilling holes to take care of the two other O2 positions we need. How will a garage be able to install sensor mount holes once your engine is installed? I suggest you get that done before install, I'll be a lot cheaper too. You could concave them by hand on a grinder then get them welded in place.
I'll just get them to install the holes on the downpipe.. :/ Engine's already installed.Daninski wrote:I just read your post about the headers only having two o2 sensors positions after I had already PM'd you. Once I get my headers I'll get stainless nuts fabricated to properly fit the periferal of the pipe. Then have them welded after drilling holes to take care of the two other O2 positions we need. How will a garage be able to install sensor mount holes once your engine is installed? I suggest you get that done before install, I'll be a lot cheaper too. You could concave them by hand on a grinder then get them welded in place.
- Gord
Days 5 and 6 added to first entry. The engine swap is done! She is back on the road.
I'm throwing a bunch of trouble codes that I'll have to work through over the next few days, but for now, I'm happy to say the swap was a success.
- Gord
Updated (see first page for details).
- Gord
wow man very nice mx-3. congrats and good luck with the car
93 GS SE - Raspberry metallic. K8 - 2 1/4in exhaust w/Magnaflow street series muffler, Custom intake, Kyb Gr2's w/Apex springs, Full kenwood audio - SOLD
Dude thanks.jbud1291 wrote:wow man very nice mx-3. congrats and good luck with the car
- Gord
lol i kno. i love the feeling i get when i fix something on the car myself its the best. i cant wait to start modding mine ![Freak :freak:](./images/smilies/freak.gif)
Installed my new spyder auto projectors:
![Image](http://lcis.dyndns.org/albums/Lifeblog/p1000344.sized.jpg)
![Image](http://lcis.dyndns.org/albums/Lifeblog/p1000346.sized.jpg)
Major improvement!
Major improvement!
- Gord
Did you read my post about the possible fire hazard from those lights? If not check it out then please post a comment.
the projectors look awesome, really makes me wanna get them
92 Mazda MX3 GS
http://www.cardomain.com/id/ukrman" onclick="window.open(this.href);return false; - cardomain page
viewtopic.php?f=46&t=66481 - worklog
viewtopic.php?f=37&t=72099 - feedback
viewtopic.php?f=2&t=71757 - stuff for sale
http://s2.metaldamage.com/c.php?uid=159229" onclick="window.open(this.href);return false; - biggest waste of time
![Image](http://i72.photobucket.com/albums/i181/ukrman28/MX-3/mx3comsignature2-2.jpg)
