Hi Guys,
Was wondering if anyone knows whether or not the miata clutch (well, an aftermarket miata clutch!) will fit on a 1.6 DOHC MX3?
Any help appreciated!
Miata/MX3 Clutch Compatability
- mx-3_4evr
Re: Miata/MX3 Clutch Compatability
Why don't you just get a performance clutch for the MX-3? I got an ACT on mine for about a year and still grips hard! And no, the miata clutch set up is different. The spline count on the disc is different and the pressure plate is different also. If you want a light weight flywheel, You can get one from a 1.6L miata, but you have to use the miata pressure plate and the MX-3 disc.
thats great.
thanks for the help!
- Limegreen mx-3
if u look around and search u be surprise what u can find.. of course other want the info handed to them to a ? that has been answered thousands of times..
http://www.mx-3.com/phpBB3/viewtopic.php?f=24&t=53702" onclick="window.open(this.href);return false;
if only u looked around ur answer was just laying around..
i saw it already.
i just had conflicting responses.
One person said it would go on with the mx3 pressure plate, and the other (boris) said it would ONLY go on with the Miata one.
And considering Boris's one is a SOHC and mine is a DOHC, and i dont know a huge amount about the drivetrain, just the basics, i want another opinion, thats all
- Limegreen mx-3
its the same i had a BP with a 1.6 miata flywheel, pressure plate, MX-3 clutch disc and on the sohc and dohc trans.(keep breaking the diff in these weak transmissions) . i don't see what makes the two trans any different...
so i will have to buy the miata pressure plate then?
damn! oh well.
any suggestions on a good brand. i've heard exedy would be good
damn! oh well.
- Limegreen mx-3
and flywheel too the flywheel bolt patterns are the same but the clutch bolt patterns are different..
hence why u can't use a miata flywheel with a MX-3 pressure plate and vice versa
