93' MX-3 GSSE - R.I.P. K8 with Integra CAI, HEI mod, Koni inserts with H&R's,drift kit, Kicker KX400.1 and KX200.2 amps, 2 kicker 12s, set of 6x9's. Custom trunk enclosure
you know what works just as well, the dust cleaners for computers. All you have to do is turn it upside down and it has the same effect, its more expensive but i think its cooler.
I will deffinatly be tryin that for my rear qt panel dent,, I can almost get it with a plunger.. maybe this will work!
1993 MX-3 RS,FULL BLITZ KIT(PROTOTYPE)17"10 SPOKE RIMS,SOHC 1.6L. http://www.cardomain.com/ride/2189811
Dali wrote:no trev it wont work, the support peice there is too close. if it does pop out it will just pop back in.
Ill try the ding king then! I can almost get the dent out with a plunger! Just need a tiny bit smaller plunger with the same sucktion!!
Jepha wrote:wow im definitely going to try this..... >_>
I am thinking the same thing. Just have to wait until summer. My mx is teal like in the video and I have a bunch of small dents like they showed too...will be great if it works like they say.
Chris--It's HOTNESS, you wouldn't understand! -- Donate to MX-3.com--It'll make you feel good! http://www.cardomain.com/id/colonelsmx3
1993 Mazda MX-3 RS-Turbo
1993 Mazda RX-7 touring
1983 Mazda RX-7 GSL
1987 Jeep Comanche
I've seen people do this with using a hair dryer also. Heat up the metal, then quench it quickly with canned air or dry ice. The biggest reason I'm not sure I want to try it is I'm worried that the quick temperature change could damage the paint/body. What do you guys think?
