I have a bpt setup and recently my oil pressure at idle pretty much drop s to 0 or below and when running it is around 12psi.
oil cunumption is very very minimal.
i am using but have been using mobil 1 extended syn oil.
what could be wrong?
thanks
oil pressure drops
- jaydog5678
- jaydog5678
onesweet92mazda
Re: oil pressure drops
hmm clogged bypass in the oil filter... or bad oil pump... try to get a shop to test it first tho
