Axle Shaft Removal
Brad
Axle Shaft Removal
Post by Brad »
I'm unable to break loose the axle shaft nut on the driver's side. It occurred to me this may have counter-clockwise threads. Anybody know? Passenger side took an air impact wrench, but came off pretty easy.
lowflyinmx3
Re: Axle Shaft Removal
Post by lowflyinmx3 »
Those things are major pains in the butt. I replaced 4 of them before and 2 I had to chisel off and the other ones I had to torch and use a cheater. try heating it. If I remember correctly they aren't reversed threaded.
Mazda.... What happens in the parking lot, stays in the parking lot
2fazed
Post by 2fazed »
When those Hub bolts are put on, you hammer down part of it, so it won't unscrew off. Did you bend that part back? Sometimes, even using an air gun, won't take it off. What I use, and works great is a 3/4 socket wrench. It's huge, and won't brake when you jump on it, using your own weight to get it turned.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
sk8erdude802
Post by sk8erdude802 »
Pretty sure there aren't reversed threaded. I replaced passenger side one two days ago. Air gun FTW.
Steve-O
93' MX-3 GS SE ZE - Sold to Acheron1502! SOLD!!!
93' MX-3 GS SE - R.I.P. K8 with Integra CAI, HEI mod, Koni inserts with H&R's,drift kit, Kicker KX400.1 and KX200.2 amps, 2 kicker 12s, set of 6x9's. Custom trunk enclosure
MyFeedBackThread
^^^^^ Click on image for my work log ^^^^^
Brad
Post by Brad »
lowflyinmx3 wrote:Those things are major pains in the butt. I replaced 4 of them before and 2 I had to chisel off and the other ones I had to torch and use a cheater. try heating it. If I remember correctly they aren't reversed threaded.
You guys have helped! I already tried heat and a cheater bar, so that leaves the chisel, which I hadn't thought of. Thanks.
Brad
Post by Brad »
2fazed wrote:When those Hub bolts are put on, you hammer down part of it, so it won't unscrew off. Did you bend that part back? Sometimes, even using an air gun, won't take it off. What I use, and works great is a 3/4 socket wrench. It's huge, and won't brake when you jump on it, using your own weight to get it turned.
Yes, I straightened out the bent-over place. Tried the breaker bar with a cheater bar and jumped on it. No luck. Guess I'll destoy the nut without damaging the threads on the shaft, somehow.
Tunes67
Post by Tunes67 »
You can also use a dremmel tool and a cutoff disc. Even better control if you have the flex shaft attachment. Allows you to be precise with your cut. Glad I didnt have this problem :) Mine came right off with my impact gun. Best of luck.
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ;)
Brad
Post by Brad »
Tunes67 wrote:You can also use a dremmel tool and a cutoff disc. Even better control if you have the flex shaft attachment. Allows you to be precise with your cut. Glad I didnt have this problem :) Mine came right off with my impact gun. Best of luck.
Tunes67
Great Idea! I was going the brute strength route, but now I'll try a little finesse.
Whisper
Post by Whisper »
I've had a heck of a time getting them off. Neither side is reverse-threaded, so you're not doing it wrong.
I got a 3/4 breaker bar and then got a 6ft long pipe, that I slid over the breaker bar, and I basically just hung off the end of the pipe and it finally cracked loose. That was rough. Those things are torqued like mental, plus with age they probably semi-fuse with the axle.
Brad
Post by Brad »
The dremel is a great idea! Wish I had thought of it. I love this forum![quote][/quote]
Brad
Post by Brad »
Glad to hear I'm not alone with this problem. Before I cut the nut off, I think I'll try a longer cheater bar. If that doesn't do it, the Dremel come out!
dave0r
Post by dave0r »
i wedge a large flat blade screw driver between the rotors cooling chanells and the brake caliper
Big 3/4 braker and 4foot bar with a extra 100kg Buddy of mine (my 80kgs isnt enough)
Jump around..grunt..swear..then BANG it comes loose
same applys when you put the new nut back on....
SOLD 1991 Mazda Astina GT, BPT,161 WkW @ 9psi, & 102wkw N/A built motor with LSD
1996 ST205 Toyota Celica GT4, big brakes, massive power
worked KL-ZE 220whp in the build, possibly for a 323 or MX3/Eunos
sk8erdude802
if your replacing the CV joint its not so important if you bung up the threads cause youll get a whole new axle with new threads and that hub nut as well.
Steve-O
MyFeedBackThread
Whisper
Post by Whisper »
Usually it's better if you don't destroy the axle thread and nut. You might need to install it back on if the replacement axle is the wrong one.
Smith18
Post by Smith18 »
WOW no, no no, you guys haha,
Do not torch it unless you are redoing the bearing to.
Simply take a 3/4 socket set (usually most people don't have them laying around unless you live out on a farm, so take and rent a set from your local auto parts store.) and its as easy as that, they come loose pretty easy with a 3/4, trust me!
1993 Mazda MX-3 GS, V6 KLZE 2.5L, CenterForce Duel Friction Clutch, Nylon Shifter Bushings (from Imazda.com), Integra Cold Air Intake, Millenia Intake Manifold, Indigo Gauges, Pacesetter Header->Resonator->2.5" piping->Dynomax Muffler, VSX Front and back bumpers from FX Designs, AWR Front and back Motor Mounts.
