Charge Light
Charge Light
My charge light on my instrument cluster has started to flicker on and off while driving. I replaced the battery as I had had it for several years but that didnt help. I had the alternator replaced with a rebuilt one two years ago. Any ideas what it might be? Hoping to get it into a shop soon, just wanted to see what if anyone had an idea what I might be in for before hand. Thanks.
- 94mx3precidia
Re: Charge Light
check the grounds to your battery, starter, alternator, and the engine ground. It could be that your grounds are too carroded.
1994 MX-3 GS KLZE, Probinator, Bully stage 1 (probe GT), B&M Short Shifter, 2 1/4" Custom headders back.
- se7en
Re: Charge Light
also, it could be a crappy alternator. I have run into that before with cheaper rebuilt ones.
They usually only last like 2 years. check your warranty, and maybe get it tested at a parts store.
7
7
1992 mx-3 GS-T, 10-12psi, T3/t4 hybrid, Turbosmart WG, AFPR, SSAC TURBO pipes, MSD Blaster coil, K&N, AEM W/B, MSnS(full standalone), 225Whp street tuned(10psi), 245Whp (12psi)(300bhp!!!)
1992 Fairlady Z(JDM RHD) 2+2 TT black(done!)700whp+
Don't Click Here! Trust me,Time waster!
Re: Charge Light
Thanks for the input. Kind of what I figured but I just wanted to make sure there werent any MX-3 specific culprits.
Re: Charge Light
The charge light is almost always, in my experience, due to the rectifier...which is in the alternator. This is where old cars are nice because the regulator and recitifier are separate from the alternator and really easy to test.
- Tunes67
Re: Charge Light
Still pretty easy to test on our cars too.. Just get out your handy dandy volt meter.. check battery voltage.. record the reading.. start the car.. and check battery voltage again. If the regulator is bad.. you will see the voltage at the battery jumping around erratically even at normal curb idle speed. Just saw this exact symptom 2 days ago on Supermans DE swapped MX-3. Charge light is on solid and voltage at the battery with the engine idle was bouncing between 13.4 on upto 16.1, Pretty sure thats the regulator gone bad. Pretty easy fix though on the V6 carsThis is where old cars are nice because the regulator and recitifier are separate from the alternator and really easy to test.
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ![Wink ;)](./images/smilies/icon_wink.gif)
Re: Charge Light
Point taken and of course you're correct. I guess what I meant to say, and was really thinking, is that to repair a regulator or recitfier nowadays you have to repair the alternator as they are internal.
