finally finished my dash swap!!
but let me tell u it was a pain in the a--
did it just before the first snowfall too
first of all if any of u guys r going to attempt it know that there is sum custom work involved
especially with the floor bracket, side brackets and a bracket that needs to be cut to let the speedometer wire through where the gauges go
i had no troubles with the steering column tho it bolted right in as well as the 3 bolts under the windshield
also there is alot of rewiring that needs to be done
there r two main connectors by the fuse box that u have to rewire
if any of u need any help jus let me no
here r a couple pictures i took with my cell phone.. not the best quality n cars still kinda dirty cuz i havent had a chance to clean it yet
before
n after
btw the interior is painted a diamond white pearl to match the exterior
before
n after
did you use the wiring harness from the 92 dash or did you swap over the 94 harness???
I was thinking you used the 92 since you did not swap over the button HVAC panel....
+1Vanished wrote:Wow does that ever look good! I thought there was too much white before, the way you had the entire dash painted, but now it looks SO much better, flows better too. The style of the steering wheel matches the style of the dash now haha..
Well done sir!
too much white before, looks freakin MINT now man
button hvac?
this one came with the slider hvac version
i used the 94 harness that was attached to the dash
all i did was cut the two main connectors by the fuse box from the 94 harness (blue and white ones)
and swapped them for the 93 ones.. its sumthin like 10 wires but its all colour coded.
thanks btw
i like it way better now
it flows a lot better ..its all curvy and nice looking
i shouldve done this a long time ago!
thanks btw
- solo_ryder
- Kirk95gs
Same as me... my 93 was the slider. Buddy of mine has a 94 rs that has the slider also.. but I also have seen button type in a 94 gsze... it was a custom dash so I dont know if the person changed it... I know all 95's that I have see have the button type...solo_ryder wrote:Most Canadian 94 hvac panels are slider style from what i have seen.Mooneggs wrote:did you use the wiring harness from the 92 dash or did you swap over the 94 harness???
yeah I had it in my 94 GS but i guess that's another difference between the canadians and americans I didn't know about LOLs1zzl3 wrote:yeh ic now
its in the shop manual
i didnt even no it existed
but ill swap it out when i c one
cuz its alot more convenient to have buttons i think
plus it looks more modern
most of the stuff on ur cardomain page i never knew existedMooneggs wrote:yeah I had it in my 94 GS but i guess that's another difference between the canadians and americans I didn't know about LOLs1zzl3 wrote:yeh ic now
maybe u should add the door sill plaque n the mx3 plaque that goes in between ur tail lights to ur list
i have never seen actual pics of them
ive seen drawings in an mx3 brochure once tho
i would love to get my hands on those
I didn't have a lot of the problems you expressed with your swap .I also didnt have to do a lot of the things you did . The only real problem I had is I had to trim the dash for the large support on the passenger side dash , and I had to custom fit my HVAC
Kris -
Kris -
93 Kandy Tangerine Mx3 GS-DE
02 Subaru Impreza OBS
& Lots of Toys to haul
s1zzl3 wrote: maybe u should add the door sill plaque n the mx3 plaque that goes in between ur tail lights to ur list
???? what is this???? are you talking about mx-3 emblems on the outside of the car???
is there a part I don't know about???? is that possible??? LOL
That is an amazing job man, seriously the white looks amazing. Very nice look, especially if it matches the exterior! I have to start posting some pics by starting a work log on my GS. ANyways, great job!
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD
Buyer Feedback: viewtopic.php?f=37&t=62426" onclick="window.open(this.href);return false;
viewtopic.php?f=37&t=69003" onclick="window.open(this.href);return false;
"Amatuers practice until they can get it right; professionals practice until they can't get it wrong"
