burning smoke
				tazman734
burning smoke
i just got done replaceing my headgaskit .  i fired it up for the first time today and it smoked when i reved it up .  the smoke was gray white when i whent to the tail pipe to small it to find out what it was the smoke burned my eyes and nose i turned it off and looked in my book " no help there " but i remaber someone a time ago saying unburnt fuel will do that any help would but great
							tazman734
						why did you change the gasket, was it blown, did it overheat and did you drive it like that, its posible that your head is warped it so you may need a new or used one or even machine it.
							1995 J-Spec Az3, BPT swap, mazda speed eibach springs, mazda speed swaybars, mazda speed exhaust, mazda speed shock tower bar, mazda speed bodykit, sr shocks, disk-brakes all around,turbox boost controler, honda del sol act pressure plate, fmic 20x12x3
