Steering wheel removal
I cant seem to get the steering wheel off.
I wanted to fix my wiper thingy but cant get the wheel off
- Aston Wards
Steering wheel Disassembly
The best way is to get a steering wheel puller.
I tried pulling the steering wheel off...but no luck...
Although I really didnt try really hard because I was afraid I may pull something else loose somewhere else.
You can get a puller from Autozone, Advance, Murrays, etc.
Its about 60-80 to rent it.
You have to pretty much pay for it in full and when youre done bring it back for a full refund.
If these pics will help...
This will only take 5 minutes to do.
I got this puller from Murrays.
![Image](http://i42.photobucket.com/albums/e313/Blazianenigma/MX3Forum/Worklog/Steering%20Wheel%20Removal/IM000843.jpg)
This one was 68 to rent/buy
Plus it was brand new.
What you want to to is take apart the horn pad by removing the screws behind it on the steering wheel.
Disconnect the horn and you should have something looking like this.
![Image](http://i42.photobucket.com/albums/e313/Blazianenigma/MX3Forum/Worklog/Steering%20Wheel%20Removal/IM000846.jpg)
Afterwards, remove the center nut then take two bolts from the puller kit and attached like this with the H shaped tool.
![Image](http://i42.photobucket.com/albums/e313/Blazianenigma/MX3Forum/Worklog/Steering%20Wheel%20Removal/IM000847.jpg)
Take the main center bolt from the puller kit and attached it through the hole in the center of the H tool. Tighten this until it reaches the top end of the steering wheel bolt.
![Image](http://i42.photobucket.com/albums/e313/Blazianenigma/MX3Forum/Worklog/Steering%20Wheel%20Removal/IM000850.jpg)
Tighten the 2 end bolts just so its snug...but dont over tighten it.
Then take a wrench or a socket and start to tighten the center bolt...after about 5-10 turns the steering wheel will come off the spines with a POP.
![Image](http://i42.photobucket.com/albums/e313/Blazianenigma/MX3Forum/Worklog/Steering%20Wheel%20Removal/IM000852.jpg)
1993 MX-3 (Converting in Oct)
2004 MS6 (Repairing)
1982 Limited Edition Me (.04Hp)
Re: Steering wheel Disassembly
[threadjack]Blazianenigma wrote:
i digg the ms6 cluster - did you swap it into mx3 (or is it the interior of ms6 (doesnt look like it)....... i am planning to swap it into my mx sometime....
[/threadjack]
excellent write up!! nice job!
![Image](http://i806.photobucket.com/albums/yy344/Mooneggz/laguna_seca_signature.jpg)
- Tunes67
Thats a MX-3 interior for sure.. cool idea on swapping in the MS6 gauge cluster.. Nice job on this writeup too.. make sure you do a write up on how you get that digital odometer on the MS6 Gauge Cluster to work too ![Wink ;)](./images/smilies/icon_wink.gif)
Tunes67
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ![Wink ;)](./images/smilies/icon_wink.gif)
