I have a fuel leak only when the car is running. It appears to be on the back side of the motor. I've looked at all the rubber lines to rail ( new last year ), filter, lines from tank, and the little C shaped metal line near the filter and I can't find it. Also, the gas cap still has vac after the car is running. Since there is a vac does this mean it must be on a low pressure line?
Has anyone else had a similar problem in this area? It's a pretty good leak causing a constant drip about every 2 seconds, only when running.
twoie
fuel leak FIXED Thanks patdiesel
- PATDIESEL
I would guess that you maybe split one of the lines when replacing them or didn't use hose rated for fuel. Not that you didn't ask the parts guy for fuel line, but that maybe he gave you the wrong stuff. I've not seen the metal lines corrode, but that could aslo be a problem. If you find corrosion on the outside of the metal lines I would replace them. Fuel leaks are HARD to find. The gas evaporates so quickly and if it only leaks when running you are really taking a chance running the car to find the leak. However, IMO it is better to run the car and find the leak now rather than wait for responses and drive the car with it leaking.
