Anyone have any experience with GUDE cylinder head packages?
I am probably going to get one for my 94 DOHC. No, don't tell me "Do a bpt swap etc. etc."...I am sticking with the stock platform and the reasons are my own. My only questions are: does anyone have any experience with the Gude cylinder head packages, and if so, about what % power increase should I expect? I have heard as much as 75 horsepower from the new head, cam, and throttle body along with an intake, headers, and full exhaust, but experience speaks louder than equipment manufacturers. I am going to rebuild my engine, and I thought to myself "Meh, why not get that cylinder head, cams, and tb for it too," so I anticipate the drive after the rebuild will be fun, as I will have brand new engine specs and a better breathing top end.
Any input would be cool. I am NOT doing a bpt swap so don't suggest it. ^_^ thanks!
- Limegreen mx-3
in boosted form it could be possable given if ur in a race setup like mine. in n/a form no where near that. maybe 10-20 whp in n/a form
I have to agree with limegreen mx-3 here, it is unlikely you will see more than about 10-15whp on a B6 motor with those mods in NA form. The B6 motor is not a performance NA motor like the B16 and B18 series from Honda or the 4AGE series from Toyota.
Boost is where the power is on these motors.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
- monty73741
i dont know.... i know vaughn has alot of mods on his sohc 323 and it has a decent amount of HP. I think SINCE the DOHC is pretty much the same engine as the 1.6l in the miata. you could look @ the gains from engine work on NA miatas
Jason Danaher
Please Help Support MX-3.com
Yea I was going to say...I mean, we are talking about a fully ported and polished, higher-flowing cylinder head, performance camshafts, and a bigger throttle body...I think 15-20 horsepower might be a little TOO conservative of an estimate.
What I think I am going to do is just dyno the car before and after! Because I kinda want to do this regardless, and what better way to know how much horsepower it made then by actually checking? Would be interesting for sure.
- Limegreen mx-3
by all means go ahead. I know im still trying to prove what a stock internal BP-De in boosted form can break into the high tens. maybe low 11's in the 1/4. im already at a 12.4@118 on a BP-DE boosted mx-3.
- Limegreen mx-3
just dooooo it just dooooo it . LOL
- monty73741
i would check probe talk for a kit for the K series engine
Jason Danaher
