Yes, it came in the rs and every other car with a hand ebrake..
its not really a switch... its just a piece of plastic with a spring in it so when you pull the ebrake, it grounds out the circuite, which is completing the circuite for that light in your dash.... look for the wire there.... if you take that wire and touch it to metal somewhere, it will ground out the wire and your dash light will come on...
It's something that when the brake lever reaches the position at the bottom it causes the light to go off---and there's nothing there. Just a empty place where some type of disconnect would be fastened. And an unused empty socket where it would be plugged in, tested the wires and they go to the light in the dash.
Anyway, still need. C'mon, I know it's just a silly little piece, but somebody sell me one please...
