hey guys,
i have the service manual and it shows how to remove the dash, but ihave a question. do i really need to remove the steering column and the entire centre console? i'm grabbing a new one from a yard around here and just wanna know in advance to minimize time. any help is appreciated. btw, this is coming out of a 93. thanks a lot.
Removing dash from a 92-93
- ovendenk
kevin (aka The Oven)
93 mx-3 GS KL-ZE with KL31 cams and properly chipped ecu
All mods are on my website: http://ca.geocities.com/ovendenk
MX-3.com Worklog: http://www.mx-3.com/phpbb2/viewtopic.php?t=48462
![Image](http://ca.geocities.com/ovendenk/pics/Other/sig.jpg)
- ovendenk
thanks man. i was just trying to figure out before i went to the yard. i went yesterday and cut out my two quarter panels and was working on the dash when the yard closed.
anyways, i'm heading back today to finish her off. i have already remove the steering wheel though since i wrote that post. thanks anyways.
any chance you could email me the pics of the intsructions to remove the dash? i'm having trouble figuring it out
ProjectMx
My BP and AWD build thread
Cardomain
93 Mx-3 GS with bp and GTR AWD system
93 Escort GT daily driving
Cardomain
I tried to remove it.. and I gave up :S
BUT thats my next project tho.. I HAVE to replace the dash.. mine doesnt give the car justice.. :S
-hec
92-93...D Shaped vent Dash right?
Its a pretty tedious task...
Ill see if I have the pics and can remember the bolts to remove.
There are 2 on both the left and right side
and you will have to remove some bolts right at the windshield...that one in the center is a pain in the azz.
But youll end up here.
![Image](http://i42.photobucket.com/albums/e313/Blazianenigma/IM000453.jpg)
![Image](http://i42.photobucket.com/albums/e313/Blazianenigma/IM000452.jpg)
I took this dash out a few weeks back but I do have some pics.
Ill see if I can dig them up off the camera and reconstruct my deconstuction.
1993 MX-3 (Converting in Oct)
2004 MS6 (Repairing)
1982 Limited Edition Me (.04Hp)
I've also removed a few of these dashes... not too difficult
you basically just start by taking off all the console pieces that you can (mostly with a philips screwdriver) the hardest part for me was taking off the upper dash trim where the vin number is... I had to us an L shaped screwdriver since it is so close to the glass.
be careful taking the vents out because they are prone to cracking/shattering because the plastic becomes brittle.
Basically most of the bolts holding it in are 10mm and you can use a long extension to get the ones in the corners by the doors.
you'll also have to take out the speedo and all little switches and such.
![Shocked :shock:](./images/smilies/icon_eek.gif)
![Image](http://i806.photobucket.com/albums/yy344/Mooneggz/laguna_seca_signature.jpg)
where did u get the L shaped screw driver?
-hec
lol luckily I lived next to walmart at the time... it's basically ummm actually it's shaped like an "N" I guess stretched out... LOL I can take a pic if someone really needs it hahahgallegos915 wrote:where did u get the L shaped screw driver?
but you need some type of L shape to get that screw out... or some kind of flexible screw... cause I couldn't get a mini ratchet + 10mm in there...
