ABS Light on After ZE Swap
Hey guys I have a problem. Before the ze swap everything worked fine. Afterwards the abs light is on and the car seems to break a little less effectively. The other question is where does the vacuum hose from the break booster go. Right now it is connected to the back of the intake manifold. Any help will be appreciated.
