b6-bp swap? how good is this exactly?
A forum for Drag Strip/Track Racing Discussions. (NO Street Racing or Kill Stories, they WILL be deleted.)
mazdamx3sohc
Post by mazdamx3sohc »
im just asking a question everyone with a stock b6 wants to know...in all seriousness we all race em time to time with the b6...i AM doing this swap from sohc to bp...right now i beat pretty much all civics, unless they are aspirated...i beat a lot of decent cars...what kind of cars do you beat with a stock bp motor? and how much of a difference did you notice from the stock motor to bp?
Limegreen mx-3
Post by Limegreen mx-3 »
u'll find out when u finish doing the swap.
mazdamx3sohc
yeah but i wanna know. lol thats what this forum is for man lol.
JWMotorsports
Post by JWMotorsports »
We had a lightened MX-3 with a stock NA BP, stock headers, Whalbro 255lph fuel pump, 9lb SPEC flywheel, S-AFC, Jacobs Ice Pac, Nology Plug Wires, custom intake, custom exhaust (headers back), NGK V-Power Plugs gapped to .065 (no thats not a typo), ACT pressure plate with 6-puck solid hub disc and the ignition majorly advanced...I'm talking 25+ degrees at idle. It would walk stangs...easily. Then we added a Mitsu 16G turbo, RC 440cc injectors, side mount IC and at only 7psi it made over 190WHP and over 200ft/lb of torque. That setup spun all the way down the track to 9 flat all day in the 1/8th mile.
mazdamx3sohc
nice what kind of psi can a stock bp motor handle max? safely.
Cy
Post by Cy »
JWMotorsports wrote:We had a lightened MX-3 with a stock NA BP, stock headers, Whalbro 255lph fuel pump, 9lb SPEC flywheel, S-AFC, Jacobs Ice Pac, Nology Plug Wires, custom intake, custom exhaust (headers back), NGK V-Power Plugs gapped to .065 (no thats not a typo), ACT pressure plate with 6-puck solid hub disc and the ignition majorly advanced...I'm talking 25+ degrees at idle. It would walk stangs...easily. Then we added a Mitsu 16G turbo, RC 440cc injectors, side mount IC and at only 7psi it made over 190WHP and over 200ft/lb of torque. That setup spun all the way down the track to 9 flat all day in the 1/8th mile.
now u see..THAT'S what i wanna hear...
mazdamx3sohc wrote:nice what kind of psi can a stock bp motor handle max? safely.
i've heard 18psi WELL TUNED and it'll run for atleast 30K...
Safe psi i'd say 12-15 still on a 11.5:1 or MAX 12:1 tune...
mazdamx3sohc
what kinda horsepower will that be at that psi? also i dont really know much about ratios and how they work if someone would like to school me.
Cy
Post by Cy »
mazdamx3sohc wrote:what kinda horsepower will that be at that psi? also i dont really know much about ratios and how they work if someone would like to school me.
depends on the turbo...T4 probably...he's getting 200hp on a small/medium turbo...@ 7psi tuned...
Rough guess....double that and a bit...your looking at between 375 and 450whp..
mazdamx3sohc
thats crazy i gutta get me a t4 turbo and put out 14 psi.
JWMotorsports
lol...you put a T4 turbo on and your power band won't start untill about 4500rpm. A T4 turbo is verrry laggy under that rpm on the 1.6 or 1.8L engines with out using anti-lag, or nitrous.
The turbo we used on the BP powered MX-3 is a small Mitsubishi 16G which is one step larger than the Mitsu 14B that comes stock on the Manual trans first Gen DSM's. It is a very good street turbo as it has just a bit of lag out of the hole but is very responsive most every where else. It is hard to beat when only looking at price.
The lil 16G can be picked up really cheap brand new ... http://www.forcedperformance.com
It only flows enough to support up to around 320HP and shouldn't be pushed much higher than 21ish psi in bursts...it has about the same peak flow or a bit less than the Garrett GT28RS Disco Potatoe and costs only about 1/3 of the price. After about 21psi though the lil 16G outlet temps sky rocket due to the small A/R compressor housing.
The BP and B6 engines with the small rods (they use the same rods except in the GTX and GTR engines which are beefier and interchangeable) can hold around 300WHP reliably (on the small rods). The upper limits for the small rods & cast pistons is about 400-450WHP @ 26psi which works for about 10,000 miles before it wears out the rods and snaps them just below the wrist pin (cyclic fatigue). Boost honestly doesn't make that much of a differance as long as you use a good intercooler and feed it fuel. What matters is the engines total power output. The HP & torque is a direct result of the force that directly loads the rotating assembly. The higher the force the higher the HP & torque. They are directly connected. Boost is some what decieving. For example a lil 16G will make around 320HP @ 21psi....replace that turbo with a GT3076R and it would make around 400HP @ 21psi. Even though both turbos are running 21psi the GT3076R is putting a LOT more stress on the rotating assembly at the same boost pressure as the lil 16G. The reason is because the larger turbo moves more air per pound of boost than the smaller turbo. More air means you can burn more fuel. More fuel being burned is what makes more HP & torque, directly causing more stress on the rotating assembly. This is just a glimpse into the infinate factors that determine engine life. You need to monitor BOTH AFR's and EGT's to properly tune any engine. EGT's are only good for an early warning system that melt down is approaching. AFR's tell you what is going to destroy your engine. To rich washes the walls and wears out the rings and walls quickly...to lean turns your engine into a metal foundry. :wink:
Cy
Post by Cy »
just as an inquiry...also this may help MazdaMX3SOHC...
Protege 96 BP (looks like a Mx-3 DOHC16)
I think I've said My goal is 200-230Ft-lbs with any Horsepower figure..
I have a T3 .42 gated at 10psi...
I'm planning on getting the ETDRACING.com BP FWD manifold...
I have a Rising Rate Adjustable FPR coming soon...
I will get an Ebay Intercooler and make my own piping from Crappy-tire steel pipe, bent to fit and then powdercoated..
Exhaust getting redone post turbo..2.5" sounds like plenty for a 16 @ 10-12psi...
I don't plan on upgrading anything other then maybe a MSquirt sometime in the fall..
AFR, Vac/Boost and EGT guages in 3 weeks...
Anything i should add to that list?
mazdamx3sohc
i wanna get as much horsepower out of my stock bp motor without hurting it, so im guessing just bp/16g turbo/huge intercooler as well as all the other accessories, would that be the way to go? and at what realistic psi without damage, what do you think itll put out about?
Limegreen mx-3
u guys think small LOL j/k i retact my statement i don't want no war. I want a SC67-69 turbo and a 600hp rated intercooler from percsion turbo now thats a T4 size turbo small one but thats what i want. (compared to the larger T4's i mean.)
yes iam aware of lag but the intentsions i have is for a full race setup no more street mx-3. and i have aother mx-3 im boosting yahhh to sohc power yahhhhhhhhhh. im not going to be so slow.
mx3autozam
Re: b6-bp swap? how good is this exactly?
Post by mx3autozam »
mazdamx3sohc wrote:im just asking a question everyone with a stock b6 wants to know...in all seriousness we all race em time to time with the b6...i AM doing this swap from sohc to bp...right now i beat pretty much all civics, unless they are aspirated...i beat a lot of decent cars...what kind of cars do you beat with a stock bp motor? and how much of a difference did you notice from the stock motor to bp?
I find it very hard to find that you beat almost "all" civics.
93 Mazda MX3 KLZE Turbo
2RotorsNaDream
Post by 2RotorsNaDream »
He beats almost all of the bone stock 1.5L Civics he meant. And I told you before after the swap the car ends up being a low low 16 to mid 16 sec car. Your car now is probably a high 17 to low 18 sec car right now. Basically you'd be able to run with Civic EXs (SOHC VTEC), last gen Celica GTs, Audi and VW 1.8T stock, and cars like that.
Return to “Drag Strip/Track Racing”
