Anyone have trouble with these before?
I'm getting 38mm on the bushings, and 35mm on the LCA hole... are these bushings for the V6 LCA's?
SRD Rear Lower Control Arm bushings...
- Shades
"Do it ONCE, do it RIGHT!"
- PATDIESEL
Did you Completely remove all the rubber from the inside of the hole? Mine pressed right in.
Oh, and grease the F out of the bolt and inside of the hole. Otherwise they will squeek like a mouse being eaten by a lawn mower (don't ask how I know what that sounds like).
- Shades
Yup, I've glassbeaded and painted it... and there's no outer sleeve left inside nor any rubber or anything. I did a search and I think that it's like the Protege ones that have the smaller hole... looks like I'll have to hit a junkyard to grab one.
- drkwing3
SRD bushings
Just went through the same thing today. There was so much play that I was getting a "clunking" noise due to the fact that the bushing was moving in the cage. Said thwi and went and got some mazdaspeed bushing.
'94 GS, custom paint, Nex-o 15x7 rims, (got tired of the squeaking) mazdaspeed bushings, tokico-Zx2, ractive bars, khumo 712's ,xm,clarion,B&M shifter, Eibach,K&N, fx lip spoiler
Re: SRD bushings
you are having the opposite problem that shades is having... if yours are loose that means you popped that metal sleeve out of the bushing holder... on the control arms when you push out the rear most bushings there is a partial metal sleave in there and you must leave it in or it wont' fit. I popped it out on accident and it made it very loose os i have to find a new one and pop the bushing out again.drkwing3 wrote:Just went through the same thing today. There was so much play that I was getting a "clunking" noise due to the fact that the bushing was moving in the cage. Said thwi and went and got some mazdaspeed bushing.
shades not sure what the deal is on yours though maybe they switched it in the later years
ProjectMx
My BP and AWD build thread
Cardomain
93 Mx-3 GS with bp and GTR AWD system
93 Escort GT daily driving
Cardomain
