93 to 94 parts
Spotted
93 to 94 parts
Post by Spotted »
What parts if any can I swap from a 93 SOHC to a 94 DOHC. I need an EGR valve, temp sensors and maybe a distributor. I have both cars. Just wondering if anything was possible, these parts are expensive and if I can get away without having to buy them that would be great!!
Thanks
:welder:
cyclonekid78
Post by cyclonekid78 »
Temp sensor should be the same.
93 RS BPTurbo
http://www.cardomain.com/ride/2628805" onclick="window.open(this.href);return false;
Limegreen mx-3
Post by Limegreen mx-3 »
temp sensor is the same
93 dissy is external coil pack
94 dissy is a internal coil pack
so they won't interchange
93 does not use a EGR
94 does use a EGR
so ur shyt outta luck there
ur best bet on ur 94 parts is the junk yard.
Spotted
Post by Spotted »
One last question. The 94 has an automatic tranny, the 93 a manual. Can I transplant the trans into the 94, or does anyone have any suggestions as to what tranny to put into the 94?
:welder:
