I have a 92 mx-3 gs and i have had a horrible time with harmonic balancers, ( crank pulleys) and i am looking for another one since i lost mine again tonight. The rubber seems to go bad in them and i found one on ebay that is after market and lighter, anyways it has no rubber and looks about like mine but it only says for an mx-3 and doesn't say either the v6 or 4 cyclinder models but also includes the escort and miata 1.8L and thats what my v6 gs is. Have any of you guys purchased this b4 and do you know if it will fit on my car?
http://cgi.ebay.com/ebaymotors/OBX-PREC ... otohosting
crank pulley replacemnt????
Last edited by wvurubberducky on March 28th, 2007, 7:23 am, edited 1 time in total.
Check the for sale section, i got one for sale, it didnjt work well on my ze. You have to grind down part of the oil housing. I did not like the results on my z3. If you have a k8 may work better? check for sale section.
-hec
- PATDIESEL
I would suggest getting the stock pully b/c the aftermarket underdrive versions do not have the harmonic balancer part. Also, the 1.8 Miata and Protoge are 4 bangers and you cannot use any motor parts from them.
