fuel mileage sucks..need ideas.
93-mx-3
i have the 1.6 sohc n im getting horrible gas mileage with it. i can burn through about a 1/4 tank in bout 3 or 4 days n i dont drive it that much or that hard at all... does nebody have ne ideas wat could be going on...i've swapped the injectors, maf, n the regulator out for the protege ones but i wouldnt think itd decrease mileage that much..wats your opinions??????
live life a quarter mile at a time.
life is about learning from your mistakes and not regreting them.
- Yoda
Have you changes that O2 sensor? On the SOHC the should be changes about every 60000-90000km. Even then they are pretty dead. The stupid thing about them is that they can be totally dead and not throw a code. I converted my old car to a 4 wire O2 because they have a little more bandwidth that a OE single wire and isn't dependant on EGT to get the sensor up to temp and the other reason is I was a bunch of them I stripped of scrap engine at a JDM shop. As I remember my mileage jump from about 10L/100km up to 8L/100km.
Pin hole leaks in your exhaust especially before the Cat can equal a small fuel economy loss. The flex join is the usual place to find this leaks at the best of times. On the other end pinhole leaks in the gas filler neck and gas tank will affect not only fuel economy but power as well. An oversized aftermarket exhaust and muffler can have a negative effect by killing off the bottom/ mid power.
A bad chassis and engine ground will also affect fuel economy.
These three things should made a night and day difference not only in fuel comsumption but power you didn't know you lost as well as long as the compression is still good.
In the end before scrapping my car I was averaging 7.3L/100km or about 32mpg in mixed city/high traffic.
93-mx-3
ok...i gotcha...so get the o2 sensor..cus i have 172,500 miles on my engine and im pretty sure its never been changed...n also check the ground..im almost positive me exhaust is good...but ill check that too...
- Limegreen mx-3
there like $20 at autozone single wire O2
- Tropical Emerald 1993
- 94blaze1.6
- Typhoonk
another easy check is your oil pan drain bolt. Had my oil done at a place and they didn't not tighten the bolt properly and my oil pressure went done (didn't lose a lot of oil so no crazy damage). Cut my mileage in half
just something to check
PM for info
PM for info
I have turbo dreams and detanation nightmares
