BP screeching
BP screeching
ok every time... or pretty much every time i start up the car it will screech like the belts are hitting something... i checked the belts and they are good... but unless i give it gas to go above like 2000 rpm then the screeching will stay... it usually only does this when i start up the car... but last night it would do it every time i left idle and went on the gas (stoplights and stuff)... timing belt, waterpump, belts, and pulley all new...
- Limegreen mx-3
tighten ur belts a loose belt might cause that noice
- Shades
I bet it's your alternator/water pump belt... that one always like to make a bloody noise.
"Do it ONCE, do it RIGHT!"
