ZE on 5PSI untuned 2nd gear to end of 3rd pull.
- XxantwawnxX
Just a veery quick vid of my pulling from mid second to end of 3rd. She is still untuned just running off th ebase map that the probetalk BB offered for my megasquirt.
KLZE on 5PSI (with ghetto rig hot pipes : P)
It puts my head back in the seat man i love it.
http://members.cox.net/antwawnhayes/ZE5psiuntuned.wmv
holy cow... that turbo sounds sweet!
-hec
man can you hurry up i wanna come get my i mean look at your car
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
please get a take off video with someone outside of teh car
- mx3autozam
- XxantwawnxX
*cough cough* i would take out side pics of it...but its really looking junky atm because of my ill fitting Plexiglass hatch(soo light from like 75 pounds to 24 pounds) and my fiberglass hood they booth came from some racing mx3. Now all i care about is that there light....but the colors dotn match and they look pretty bad. BUUUT i plan on getting th ewhoel car painted black soon and i think that should make it more presentable.
then*cough cough* i might make an outside vid
oh and thanx everyone
i demand outside shots! it will be so fast your car will be blurry anyway
- PWRD_BY_HKS
who built it.... did you do everything your self?
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
someone mentioned plexy glass? wow not i wanna turbo my new coming ze.
-hec
- MechaManZero
This makes me want to freakin amke more money to get my turbo project done. Sounding sweet. What BOV did you get?
Çlark
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
- XxantwawnxX
Everything i did myself except the welding of the hot pipes(although i did design them and tell the welder how to do it...i cant weld) and of course i used someone elses base map for MSnS.PWRD_BY_HKS wrote:who built it.... did you do everything your
self?
HKS super sequential (not a knock off)MechaManZero wrote:This makes me want to freakin amke more money to get my turbo project done. Sounding sweet. What BOV did you get?
yea i dont have a glass hatch...all plexi. Looks ugly and fits liek crap...but man is it lighter : )hgallegos915 wrote:someone mentioned plexy glass? wow not i wanna turbo my new coming ze.
