93'... I am about giving up on this one. Does anyone know where you can get replacement door locks with keys? I've tried everywhere.
Trish
Replacement Door/Hatch Locks
shitty deal
ya man about the only place you may get the keys and locks are from the stealership.. might occasiuonally get it from the wreckers... but many ppl dont give there keys in.. good luck though
- PATDIESEL
If you get some from a wrecker or J-Yard you can have a key mede by a locksmith for about 75 bucks. If yours are sticky or breaking keys, try getting some graphite from the local hardware store, usually in the door knob or key section. Squirt some into the lock and turn it with the key a few times and it will get much better.
If you send me your ign cylinder i can get a key made for 3 dollars... well bnetter than paying 75? to change locks yup..delaership or a whole parts car and send me the ign switch and i can send u a copy..i have 5 keys to my mx3.. i know i over did it but hey its 3 dllrs a pop why not..
-hec
- PATDIESEL
DO NOT use both silicone spray and graphite. You would create a sandy cookie dough that would gum up everything. Use one or the other and stick with it.
I bet you've used both and are probably ok for the moment or maybe cannot notice a difference since the locks are messed up already. On a good set of locks that just need to be lubed it would not be a good idea.
