Tokico Blue struts
ryanlindenberg
Tokico Blue struts
Post by ryanlindenberg »
I just order a set of tokicos, i'm just going to run stock springs for now since it is a daily driver and it snows here. Anyways, what else should i get while i'm redoing the suspension?
I'm thinking:
dust boots
thrust bearings (are they only on the front or all four?)
anything else i should replace while in there? are there gaskets between the strut mount and frame? i've never done suspension work before so i'm kinda clueless.
CARDOMAIN WITH UPDATED PICS
solo_ryder
Post by solo_ryder »
If you are going to lower it consider a set of camber bolts for the front abd back so that your alingment ais not effected.
ryanlindenberg
Re: Tokico Blue struts
ryanlindenberg wrote: i'm just going to run stock springs for now since it is a daily driver and it snows here.
Steeb
Post by Steeb »
you can probably use your stock thrust bearings if they are still ok. only the front needs these.
get an alignment after.
solo_ryder
I realize that, I was considering the fact that you may do this later.
ryanlindenberg
yea i probably will lower it later, but i'll just put the camber bolts in when i put the springs in too.
for the dust boots: do the tokicos come with them or do i have to buy some? if i do have to buy them, are they all the same? or do i need ones specific for the tokico's?
thanks for the help so far.
solo_ryder
hey, when i got my tokiko blues they did not come with dust boots, but you can use the stock ones or get new universal ones from a parts store. There is no gaskets between the strut and the mount.
ryanlindenberg
sweet thanks man
Hoodzy
Post by Hoodzy »
ahah off topic but u have the mx-3.com car minus the side skirts but closest i've seen
1995 Creek Mica Blue GS
ryanlindenberg
yea actually i have sideskirts sitting in my closet right now. the same ones. haha. then the only difference will be the rims.
Vanished
Post by Vanished »
there are no gaskets that you need to replace. ALTHOUGHT. If your strut mounts are cracked or rusted (usually the front) then you will need new ones. I beleive KYB sells some..
Also look into getting new bumpstops if your old ones are warn. Don't wanna wreck your new stuff do you? Also any reason why you chose the blues over the zx2 ones? zx2 struts are way cheaper, and aside from the dremeling (2 minute job), a direct swap.
Now, I'm going to tell you now, get new springs...you have better struts, and you plan on lowering one day, so you might as well do it now. As for daily driver/snow stuff, mine is also a daily driver and it snows here too...about 6 months of the year, and the other half are construction. So far i have had no problems with my ZX2 tokico's and eibach springs. The only thing is driveways, just gotta take her at an angle...i suggest that if you want to replace your springs, do it now. You wont' regret it.
1992 Blaze MX-3 GS *R.I.P.*
1993 Blue 93 SE-ZE
http://www.cardomain.com/ride/2770987/2
ryanlindenberg
yea a friend of mine who used to own an mx-3 lowered his and he said he didn't have any problems. he had the factory bumper though, i'm just concerned that my mazdaspeed front would crack if i hit some snow with it when it is that cold (fiberglass). maybe i'll throw my springs in now...i'd ahve to wait for my next paycheck to order them though. :(
