hey guys, i have 212,000k K8 and tranny for sale. LOCAL PICK UP PREFERED. located near barrie, pm for details.
removed the entire front end, ei subframe, engine, tranny, harness, steering rack, spindles, suspension, wheels.
on that note, the K8 has 145-150 psi per cylinder, it drove very strong, it was definately faster than my BP. its a fairly clean exterior as well. i drove the mx3 about 5 times (lightly, once spirited) and it seems to be very smooth. this includes the motor, and all accessory bolt ons. looking to get $200
the tranny is in perfect working order, shifted great into the gears, no crunching, grinding, popping, and the shiftlinkage appears to have all new bushings so it doesnt have ANY play at all. currently has 75w90 gear oil to keep things lubricated. shiftlinkage will come with this tranny, unless you dont want it. looking for $150.
94 GS wiring harness COMPLETE with JE-50 MAF, and K8 ecu...make offer
94 GS 2.25 exhaust piping, VERY CLEAN, almost new. no muffler. $75
94 GS calipers, front/rear. all calipers worked fine, drivers rear is new. can clean up and paint for an extra $20. make me an offer.
94 GS front shocks, will come complete, the spring is broken, but in the sprint purch, so it hasnt warn out the shocks. $30
94 GS 5 spoke rims w/ tires. very clean rims, 2 tires will need replacing down the road. $125
also, axles, steering rack, front spindles, parts of subframe, mounts, rad
JACK
[FS] MX-3 DRIVETRAIN
.::Mazda::speeD::.
working on the 2nd part
- mx3autozam
