My car is doing something really wierd after 30mins of drivi
It seems like the throttle body cable or something gets stuck a little and leaves the car reving at 2,300RPMs when driving (I notice 2.3k RPMs when I put it in Nuetral).
I wont have to press the gas and the car will just accelerate by its self slowly.
In order to stop this I have to put my foot underneath the pedal and push the pedal up to put it back to normal but even then, when I hit the pedal down again to start accelrating it gets stuck again
How should I fix this?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- ruthless_mx3
yeah what he ^ said
mine does same thing, but mine will also randomly fluctuate the rpms at idle between about 600-1700rpm. Revs up revs down up down and so on. The only way to get it to stop, which still doesn't always work, is to rev it quickly to round 7000rpm. Not something I want to have to keep doing and besides you look like a moron when your sitting next to a minivan at a light and your reving like you want a race.
I am assuming it may be because I have kl31 cammed klze with millenia manifold and TB, stock k8 air meter, and kl31ecu, and crappy intake.
I would like to do the megasquirt's full control setup to eliminate ecu all together. I missed the BulkBuy on probetalk does anyone know where to get the setup that comes with the maps already set close to whatever mods you may currently have?
your tps is out of adjustment, look in the faq on how to adjust it, my car does this too, it the first thing im doing next weekend.
Bochek
Bochek
Adam Bochek's 93 1.6L SOHC http://www.bochek.ca/car.gif
wow, just read the faq, I didnt really understand much of it
Where is the Throttle Positioning Sensor at? How does it look like?
I dont understand what he means by:
What does he mean by continuity?
Throttle stop screw and throttle lever? Whats that?Insert .006" (0.15mm) feeler gauge between the throttle stop screw and throttle lever
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
by the sounds of things, you eather need to find another mx'r that knows how to do them, or print out the faq and take it to your mechanic and have him do it.Juans_93_MX3 wrote:wow, just read the faq, I didnt really understand much of it
I dont understand what he means by:Throttle stop screw and throttle lever? Whats that?Insert .006" (0.15mm) feeler gauge between the throttle stop screw and throttle lever
Bochek
fuckn MX3 is nothing but problems
If I try fixing this myself, am I risking messing something up?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- ruthless_mx3
what about the VAF? How important is it to have the JE50 VAF. I've heard about it but there hasn't really been any discussions about it. I've finally reallized that the closest matching ecu for the curved neck manifold is the domestic mx6/pgt ecu. Noone has really said much about VAF though.
If the TPS was off wouldn't it be off all the time, always causing wrong/sparatic idle, not just after driving for a while?
Ok, I guess I will try cleaning the TB
But say its the TPS and I try to fix it myself, do I risk messing osmething up?
Oh yeah, can someone please answere my questions I had about what that guy meant on the FAQ?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- Custom_V6_Limited_SE
Re: My car is doing something really wierd after 30mins of d
Correct me if I'm wrong, but if pulling the accellerator pedal back had any effect on the car wouldn't that mean that the throttle cable is adjusted too tight? (Or that there is a bad spring)Juans_93_MX3 wrote:It seems like the throttle body cable or something gets stuck a little and leaves the car reving at 2,300RPMs when driving (I notice 2.3k RPMs when I put it in Nuetral).
'93 MX-3 GS SE:My Mods
- ruthless_mx3
- BornSticky
put some dry grafite in the clutch line it could be catching mine used to do it where you have to pull it up with your foot till i did that
#5389 to join MX-3.com
I guess I will just remove the TB tommorrow
Last time I tried (didnt have much time) the acceleration cable spring thing by the TB would not get off. How do I remove that part (I think its called the throttle lever. The thing with the acceleration cable wrapped around it)? I took out the bolt by it, are there any left or do I just try my hardest and pull it off the throttle body? I removed a TB on a 5.0 Mustang before, this one is a tough one.
I dont understand what this means by:
I know what a feeler gauge is, but what does he mean by "throttle stop screw and trottle lever"?Insert .006" (0.15mm) feeler gauge between the throttle stop screw and throttle lever
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
