haltech map
bugzy's mazda
haltech map
Post by bugzy's mazda »
Ok I finally saved enough money and bout a haltech standalone unit for my bpt mx-3, noe all i need is to program does anyone have a the maps or can help program the fuel maps for my mx-3. I cant wait to run this car in the tracks. Any help will be much appreciated.
Ride fast and ride hard you only live once.
ryanlindenberg
Post by ryanlindenberg »
i can try to send you one. the reason i say "try" is that everytime i try to send it to someone through email it seems to get corrupted or something.
CARDOMAIN WITH UPDATED PICS
Limegreen mx-3
Post by Limegreen mx-3 »
u should have got a tec 3 but work with what u got there good 2 haltec
Cy
Post by Cy »
Does your model of ECM have a automatic map based on a target AFR Function...
if you use that it will create a base that you can then Dyno tune from.
bugzy's mazda
no i don't think so. I Have a 1993 model. But thanks for the help i'm still trying to work out the bugs out of the system. By the, ryanlindenberg can you and try and send me the map anyways My e-mail is jerseydevil31@aol.com. and again thanks for the help.
