right hand front headlamp problem...help!
Geeman
Post by Geeman »
my headlamp is only lighting up on full beam or side lights...not main/dipped...any ideas? changed bulb...no difference
It only does what to the gallon?!
Grants
BANNED Member
Post by Grants »
Theres only one wire that comes from the controls so it can't be the relay, switch, etc. It also won't be the ground if high beam works. Your gonna have to look for a bad connection between the 2 lights, at the plug, etc. Failing that, just run a new wire across to the other headlight and solder it onto the low beam wire at the one that works.
Good luck with it!
Chemical
Post by Chemical »
Not knowing much about these lights but is it possible the bulbs at fault? I know on older cars I've had it was.
