Clutch Vibration
Dragonwight
Clutch Vibration
Post by Dragonwight »
Hi
I have a vibration coming through the clutch pedal which increases with revs it only started yesterday. If i put the clutch in it stops. Also does it when the car is in neutral. I have no problem getting it in gear no grinding or anything and the clutch engages about half way up on the pedal. Any ideas?
J0HN_R1
Post by J0HN_R1 »
:shock: Sounds like your clutch-disc is deteriorating (breaking apart) or maybe the flywheel is FUBAR'd... Either way, you wanna get this checked out ASAP before really serious damage occurs...
:wink:
When this thing hits 88mph, you're gonna see some serious TIHS...!
hgallegos915
Post by hgallegos915 »
that happened to me, when you tear it appart youll find the pressureplates teeth broken, clutch my be ok but well replace it anyway... its just that what sokme of em do when its time to change the whole thing. Youll get a screeching noise in a few days eventually the pressureplate will stop working and u wont be able to shift and be straned and only wayu to go home is floating gears and avoiding to stop.
-hec
gfreire
Post by gfreire »
a towe truck would be a beeter idea in getting home. Or get the car checked before that happens.
[FS] Carbon Fiber Alteza Tail Lights used
http://www.mx-3.com/phpbb2/viewtopic.php?t=54541
[FS] 17' Motegi DP6 Hyper Black rims
http://www.mx-3.com/phpbb2/viewtopic.php?t=54497
