[WTB] KL-ZE distributor and harness. (external coil type)
Management is not responsible for lost or stolen virginities.
White 94 Mx-3 BP
Black 93 Mx-3 Kl-De
White 94 Mx-3 BP
Black 93 Mx-3 Kl-De
- hppwdn
I think I have one, but I don't have cap. It was broken when I got my ZE. If you want the disty let me know and I'll try and find it. I think I know where it is, just haven't actually looked at it in awhile.
- hppwdn
My ZE disty is apparently gone. You can do an external coil set-up without the ZE disty. If you have the cap with the spot for the coil the hardest part is over.
Look over on Probetalk for MSD installation threads and you should find more than enough info.
I don't know what year your car is, but the wiring does vary by year.
- babyblueMX3
why the harness ? if it's for the ze disty then you don't need it. just hack the stock stuff and you'll be good to go..at least I didAteana wrote:yeah i have a cap but i dont have a wire harness either? oh hey if your using an msd 6 and blaster 2 coil i need some info too if you dont mind
RIP 400whp ZE-T MX-3
because my kl-ze disty has a bad cam angle sensor and i just bought the car they person i bought it from tried installing a disty with an internal coil so i had those harnesses attached... he did include the kl-ze disty but not the four pin harness
White 94 Mx-3 BP
Black 93 Mx-3 Kl-De
White 94 Mx-3 BP
Black 93 Mx-3 Kl-De
- babyblueMX3
you don't need a 4 pin harness..just go to the junk yard find a mx-3, snip the fuel rail clip. It is the same as the klze 4 pin connector that's the one I'm using
sweet now all I need is a new klze disty and i will take a trip to the junkers.. hey by any chance are you ryan.. used to live in mississauga? well bordering oakville off winston churchill
[edit] nm your steve my bad..
White 94 Mx-3 BP
Black 93 Mx-3 Kl-De
White 94 Mx-3 BP
Black 93 Mx-3 Kl-De
I have a pretty good kfze externam coil disty..same as klze, except the cap has the coil thingy cracked ..I dont need it AT ALL..you can have it for any price... like my old ze...this will go to the trash can if no one gets it..
-hec
