Removing Headlight
goldenarms0227
Removing Headlight
Post by goldenarms0227 »
Is there an easy way to remove headlighte so they can be cleaned?
ccreech
Post by ccreech »
You can clean them on the car...if you want to clean the inside you have to remove them from the car. I think there are 4 bolts two up top...one towards the center of the car and one on the lower outside (accessed through the turn signal hole.) Once you gently manuver it out, follow this procedure...http://www.projectmazda.com/howto/headlights/
Props to Gro!
93 GS KLZE Straight Neck (Parked)
Green Turd of MOCA
Car Domain
