BP harness, who has actually used one?
Hrmmm, posted up some other thoughts in the list of gotchas, but this is about the harnesses. Who has actually used one that says 'swap it straight over'?
There are a couple of plugs different.
Fuel rail -match to bp minus one single black/orangestripe wire that I can't seem to find where it goes with all the BP stuff lying around.
AC plugs if yours didn't have it
transmission - match to G series sensors on trans
The oil sensor plug is further to the right on the SOHC 'starter harness'
I'm not 100% confident in the statement 'just use the BP harness' at the moment as everything was seemingly matched up where it should be and there was a faint electrical smell in cabin with just key on (hot components). I disconnected battery and may swap back to SOHC engine harness as something isn't right here. I haven't tried to start it yet, but don't deem it 100% safe to do so.
- atlantamx3
- atlantamx3
what year/model was your harness from? Did you check the color code of the wires on the ECU end plugs? There is a cooked resistor in my ecu (resistors normally take a ton of heat) so I've got something out of place somewhere (perhaps grounded where it shouldn't be), or something is different with this harness. I was so tickled pink with the smell yesterday, I just left the car alone to sit by itself... in the corner.
I dunno.... looks like some differences in colors of wires, and addition/subtraction of some here and there, but I don't know for sure that things are not lining up. There was a nearly imperceivable nick on one of the wires by the ecu that it could have been resting against..
so what was your harness from?
- atlantamx3
Hrmmm... I dunno, mines 93 EGT... for the hassle of trying to figure out where all the different color codes are going and if one of them was the problem, I just put in the sohc harness. SOHC ecu started to get hot quick on EGT harness as soon as the key was turned, no hotness resistor frying with the sohc back in...
Not sure if something going to a/c that my car doesn't have was switched around or what.... either way. BLAH! PITA
The bp harness should plug right in to everything, besides the fuel rail. You'll need the fuel rail harness from a bp, but other than that everything should plug in. Basically, if it doesnt fit there, it doesnt go there. You need the bp ecu also, and a you shouldnt have a problem with a 93 egt harness, if you do, your problem is elsewhere. Peace
Ok, who is using the EGT harness?
Everything pluged in where it should have, there are a lot of switched around wires and colors on the pins to the ecu that may include some grounds to switches and such that are not there on my sohc vs. the Escort. ECU also controls items inside the car, and there must be some difference between the EGT I had and the MX3. It's not uncommon for manufacturers to change slight details between years and makes.
lol, yeah... for you!BuGS wrote:I used the harness out of a 93 Protege LX. It was nice.
It would be nice to hear from someone else who try to ran the EGT harness. Perhaps put in the FAQ - Don't put in or it will fry your ECU.
Put the SOHC harness in, started up on second turn... no smoke show from the ecu and all I changed was the harness.
Now to flush the brakes some more, put on the tires, and let it run.
