Osaka SUCKS, do NOT go through themKenzie wrote: http://www.osakajdmmotors.com/intromazda.htm
Rode in a ZE mx3
93 GS, KLZE, KL31 ECU, Centerforce Stg 3 Clutch, 2.25" Exhaust w/Flowmaster muffler, OBX Headers, Pheno Spacers, Front & rear X-drilled/slotted Rotors, KVR pads, SS brake & clutch lines, Ractive Filter, H&R Springs, Tokico Blue Struts, 8mm Accel Wires, MSD 6A w/ Blaster 2 Coil, HVAC Indiglo Panel. *Sold*
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
- babyblueMX3
agreed 100%
screwed a lot of people here..
they don't know the difference between klde and klze
RIP 400whp ZE-T MX-3
I can be a complete retard at times so correct me if I'm wrong here...babyblueMX3 wrote:must be something wrong with the track....
In Arkansas (state just North of Texas incase you don't know) our tracks are shorter than most are use to. We use 1000ft tracks whereas most of you use 1/4 mile (?) I'm not sure if it's the same in TX but maybe that's what time he's referring to. But then a 13.9 would be pretty slow for 1000 ft. ????
Here's our local website's timesheet: http://www.arimport.com/forum/index.php?showtopic=147
::'94 MX-3 GS::KLZE::
- XxantwawnxX
Yeah haveing a ze is great. *makes nice guy pose..teeth sparkle*
- papa roached
i have rode in a ZE MX-3 too, everyday to work
hmmm
Where Would you suggest gettin a ZE ? I finally saved up a lot of money to get a ZE and get a crap load of bolt-ons for it. I checked out Osaka, but from what I hear their no good. Any suggestions? Im located in Ontario, Canada.
Im sure your local speed shop can get it for you. Over here we got a few shops that can source out a ze. They get it online I believe.
-hec
- papa roached
i got mine from Noyan USA in virginia
- Buff1110
i also got mine from noyan in va. my motor was so clean when it arrived and it runs amazzing. im in nj so shipping was only like a lil over 100bux and it came in a few days. my friend also got his b16sir2 from them and same thing the motor was clean and runs great
noyan=2thumbs up
noyan=2thumbs up
Dan
92 Mx-3 Gs, KLZE Powered!! - SOLD!!!!
02 Tacoma TRD - Daily
93 Honda del Sol - New Project
Mine came from sunsengines. It was $1200 shipped, but came very clean... I just don't have it running yet.
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
- XxantwawnxX
i also got mine from noyan. get this..i ordered a DE and got a ZE. im not complaining : P. runs great.
- jschrauwen
I'm not one for dragging but the previous owner of my ZE engine said he did a 13.8 if that's any good. I just want it to scoot good when and where I want to and still stay on the road.babyblueMX3 wrote:must be something wrong with the track....I NEVER saw a ze with all the bolts on hit the 13's with no internal works. the ones I saw was spraying. maybe it's the semi slicks
I'm a little skeptic(sp?)
- jschrauwen
Re: hmmm
Steve at A-Spec in Etobicoke (Toronto). http://www.a-spec.ca (416) 246-9949, tell em I sent you.Zbroja wrote:Where Would you suggest gettin a ZE ? I finally saved up a lot of money to get a ZE and get a crap load of bolt-ons for it. I checked out Osaka, but from what I hear their no good. Any suggestions? Im located in Ontario, Canada.
- PWRD_BY_HKS
what a bunch of haters i thought mx-3 peps would be happy but i see how it is f--- every hater out there
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
