AHHH!! HELP
thackerhacker
AHHH!! HELP
i have a 1992 mx-3 1.6.........my clutch is slipping.........it might be low hydraulic fluid.........i think it needs a new clutch.......is there any how to guides on how i should do this??
matt_fulghum
my clutch slipped even when I bought it... it's a good excuse for a BP swap
my cardomain site: http://www.cardomain.com/memberpage/793483
I really have no idea what your asking us..... A guide how to replace a clutch? A guide how to add the fluid/change the fluid? Also, what do you mean you "think" the clutch is slipping? Is it slipping or are you taking a stab in the dark? Need more info
Invisible
93 GS Tropical Emerald Metallic MTX 1.8L
thackerhacker
thackerhacker
matt_fulghum
if you're poor you're not gonna like the answer.... either pay a mechanic 800 bucks to replace it, or you gotta do it yourself.... you gotta pull the engine... sucks doesn't it? That's why I decided to do the engine swap... since I had to pull the engine anyway... but it's probably not worth it for you to swap if you're really poor (like I am now. 250 bucks left in my account... groan)
It's probably worth it to you to buy the clutch and an engine lift, and do it yourself if you have time to do it yourself.... you could save a LOT of cash.
btw... 150 bucks for a clutch kit is absolutely rediculous... I got mine for 100... and it's a good quality Exedy clutch.
thackerhacker
hgallegos915
LOL 800m bucks.. thats ridiculous.... haha do it yourself..its easy..get the manual .. doesnt the manual tell you how to do it? get a haynes manual for the ford probe gt and it tells you specifically how to do it. all you do basically is pull either engine and tranny or drop tranny, unbolt pressureplacte, remove flywheel, resirface, get the clutch kit, re alight using tool, reinstgall, alight with tranny..bingo. break it in.
-hec
Another one bites the dust...
The clutch is how I got started on this whole thing. Mine started making a bad racket when the pedal was depressed, and the engine was stalling. I took it to a mechanic and $1100 later it was still making noise and still not right. I took it back and he put in yet another whole clutch assy for free, and it was still not right (some of the noise was from the bottom of the engine).
That was when I decided to get back into doing my own repair. Then I decided to swap in a BP. Then I decided I wanted to rebuild the BP first. Then when I was installing the BP I found the supposedly new (supposedly replaced twice) pilot bearing was noisy as heck.
Now the clutch is perfect.
If you are looking for a "how to do it" guide, get a shop manual, or at least get the Chilton manual (there is no Haynes for our car). If you can't make sense of how to do it from the manual, there is no amount of help we can give you that will ensure you do it properly.
